Jaguar x type gear box oil
Old Feb 22, 2023 | 01:50 PM
Justinmoodley3's Avatar
Default Jaguar x type gear box oil
Hi guys I'm in need of a gearbox oil change (long story why) but I need it done and I need to know what gear box oil does my jaguar x type x 400 2003 2.5 v6 AWD automatic take?
​​​​​​A Mechanic friend of mine suggested I use ATF dexron 3 fully synthetic
Will the oil in the pic below work ?
Thanks in advance
Old Feb 22, 2023 | 04:59 PM
Yorta2's Avatar
Wow, looks like you didn't do much research on this site. Do some - there is plenty of information already here.
Old Feb 22, 2023 | 05:08 PM
Thank you I did I'm new and found it hard to navigate according to what I found on this site : the jaguar part no for gear fluid is C2S12120 and it is also known as
ATF JF506E
Please confirm if this is correct
Old Feb 22, 2023 | 06:36 PM
Yorta2's Avatar
Justin, go to the top of this page and you'll see a bar: Thread Tools and next to it: Search This Forum. Put a search request in that one for:
Castrol's Transmax FULL SYNTHETIC vs. IMPORT contradicting recommendations
Read the posts. This will be a start for you. I t gets deeper, but almost any fluid with the designation IDEMITSU 17 will probably do the job. You will find other views that will contradict other member's posts, so make up your own mind.
Old Feb 22, 2023 | 07:18 PM
motorcarman's Avatar
VW uses the SAME GEARBOX so that is a source for fluid as well.(VW calls it 09A)
Audi VW G 052 990 A2, Land Rover LRN402, STC53016, STC50531, Jaguar C2S 12120.
Ena_ii
Jan 24, 2017 08:21 PM
dvsadam
Sep 21, 2011 02:54 PM
