Jaguar x type start and white smoke
Old Aug 26, 2016 | 09:28 AM
ahmed shah's Avatar
Default Jaguar x type start and white smoke
Hi, i have recently purchased a jaguar x type but when i start there is white smoke and engine is loud but after engine is warm there is no smoke and the car runs fine i have cleaned the egr valve and there is a new turbo and turbo actuator.
Old Aug 26, 2016 | 02:34 PM
ahmed shah's Avatar
Also the boot doesnt open with the button on the boot lid but the key works any ideas and whether i can fit the sliding arm rest into a normal one i have tried but the hatch restricts the usage of a sliding armrest any ideas will be appreaciated
Old Aug 26, 2016 | 09:19 PM
Thermo's Avatar
Veteran: Navy
ahmed shah, because you have a turbo on your car, this tells me you have the diesel engine. Having white smoke come out of a diesel is normally a sign that the engine is running lean. So, this would tell me that odds are you have an injector that is sticking when the engine is cold and one cylinder is not getting the fuel it needs. This is where a mechanic will be able to test the injectors and tell you which one is your problem. the only possibility is if you are getting coolant into the cylinder. But, this would be characterized by 1) having a sweet smell coming from the exhaust as soon as the car is started up, and 2) your overflow bottle would need to be refilled periodically (say once a week) due to the level perpetually dropping. if this is the case, then a mechanic would most likely be needed to do a compression test of each cylinder to find the leaking one and hopefully it can be fixed with a simple gasket replacement.
Old Aug 27, 2016 | 09:26 AM
ahmed shah's Avatar
hi the white smoke has stopped as we found out a spindle in the actuator restricted the use of the turbo the car is still very noisy, i have posted on other forums and have been told that it may be a tensioner which may need to be replaced
Peter Langan
26
Apr 6, 2016 01:42 PM
Noel619
Apr 4, 2016 08:18 AM
JagSTR2004
Mar 31, 2016 08:22 AM
phil51
Mar 25, 2016 08:18 PM
