JaguarVoice?
Old Sep 23, 2010 | 12:36 PM
exrub's Avatar
Default JaguarVoice?
I need your help on something. How do I know if I have JaguarVoice or not?
My 2007 X-Type has the Luxury Package, Bluetooth, Nav, Alpine...pretty much everything that was an option including the 18" Aruba wheels.
What I found out was that my LG EnV Touch is not 100% compatible so I can pair the phone with the Bluetooth but not download the phonebook.
However, when I press the voice command button, it only mutes the stereo. It doesn't prompt me for any voice commands.
Anyone know what may be the issue?
Thanks!
Old Sep 23, 2010 | 09:16 PM
Toller's Avatar
If you have JaguarVoice, pressing the button will change the left hand alphanumeric display (under the speedometer) to read "Listening." If no voice is detected, the same panel will change to something like "Command not recognized."
Jaguar just makes one steering wheel and includes the button on all of them. JaguarVoice will cost you about $800-900 as an add-on. If they had to also provide the steering wheel as a part of the upgrade kit, it would add $400-500 to the upgrade just to get that one button.
I've forgotten how Bluetooth operates without JaguarVoice. Are you certain your phone software is the latest version? I sort of faked a query (don't have your VIN) into the Jaguar Bluetooth site and found that the LG EnVTouch VX11000 was shown to be fully compatible. Maybe you have a different model<shrug>.
Eric
Old Sep 24, 2010 | 06:01 AM
exrub's Avatar
Hey, Eric!
My instrument panel only has one display (on the speedo). Of course, I never looked at that. I thought the system would prompt me like Sync does on another car I have. I was only looking at the Nav screen, and all it shows is "MUTE" when I press the button. Also, I thought it was included if you have the Nav and Bluetooth.
Here's the odd thing about my cell. I've checked everything, and like you saw it was fully compatible. However, when I had the tech at the Jaguar service check it, they said it was only partially compatible. I'll have to doublecheck the software again.
Thanks!
John
Old Sep 25, 2010 | 07:50 AM
exrub's Avatar
Wait a minute. I had a thought.
Is JaguarVoice for the factory installed phones or those directly mounted rather than connected via Bluetooth?
Old Sep 27, 2010 | 12:55 PM
Toller's Avatar
JaguarVoice is independent of the phone used...if at all. That is:
1. You can use a Bluetooth phone if the car has Bluetooth capability even though JV isn't installed. (I did for about a year.)
2. If you have JV installed, you can use it and interact with the sub-systems even though you've never owned a Bluetooth phone or don't have it paired. (My wife does this all the time.)
Think of JV as a utility off of which you can hang things like A/C, audio entertainment, .... and Bluetooth.
However, I don't think that JV existed before Jaguar had changed to the Bluetooth interface. So in short, JV is not dependent upon whether or not a phone is factory supplied. Mine wasn't and JV works. I really believe that JV is not in your car.
Old Sep 27, 2010 | 08:40 PM
exrub's Avatar
Weird! My car has the pre-wiring for JV. However, JV wasn't even on the options list.
I'm guessing you may be right in that the car does not have JV.
Old Sep 27, 2010 | 10:05 PM
Brutal's Avatar
jag voice can and was a dealer installed option. you can install it and youll need the aplicable fibre optics cable. then it have to be programmed(basiclly you introduce all the module so they will talk to each other. It functions with radio, AC and phone
Old Sep 28, 2010 | 06:04 AM
exrub's Avatar
Ah! That would explain why it wasn't shown as an option in the brochure.
I don't think I need all that fancy stuff. Heck! I have Sync on my MKZ and Focus that I don't use to its full capability.
abonano
Aug 2, 2015 07:59 PM
abonano
Aug 2, 2015 06:11 PM
Sarc
May 19, 2013 10:29 PM
JamesThurber
May 18, 2009 07:49 PM
