Knock Sensor Bank 2 Location??? Jag. X-type 3.0L
Old Mar 26, 2010 | 03:32 PM
vincek's Avatar
Exclamation Knock Sensor Bank 2 Location??? Jag. X-type 3.0L
Car is running a little funny, ran a code reader and im getting a Knock sensor bank 2 code.. So where the heck is this knock sensor # 2 ?????
I thought there was only one in the middle of the block under the injectors???
Old Mar 26, 2010 | 04:16 PM
vincek's Avatar
and it seems i cant get the RPM over 3K, I also notice my idle going up & down. I rest the codes, started the car back up and now im getting the same code (knock sensor bank 2 low input) and a mis fire # 5.. whats going on!!! shoud i drive this car down to a used car lot and pick me up a BMW??
Old Mar 26, 2010 | 08:52 PM
Thermo's Avatar
Veteran: Navy
Vince, the knock sensor is located on top of the engine, but underneath the intake. So, you will need to remove the intake so you can access the very top of the block. The JTIS also talks about having to remove the fuel rail and disconnect a coolant hose (ie, you will also have to drain the coolant system) to access the knock sensor. Doesn't sound hard, just a lot of stuff in the way before you can access the sensor.
Old Mar 27, 2010 | 11:35 AM
vincek's Avatar
My knock senor code might be due to a bad coil on # 5 cyl., I swapped coils from #5 to #2 cyl. and now my codes are pulling a mis fire on # 2 so it is a bad coil.
Will change and see if the knock sensor code goes away for good after a reset.
Old Mar 28, 2010 | 08:16 AM
steve11's Avatar
ud
Don't worry about knock sensor #2 or bank 2. As said, there is only one knock sensor on the AJV6, but standard OBD II P codes for all cars give a placeholder in the P code list for 2 knock sensors as a lot of engines use two. The AJV6 engine management system is programmed to use bank 2 as the default reporting code for THE knock sensor.
This is just a theory, but if you have a very dead ingition coil on the #5 (that you moved to #2), this might have caused a missfire enough for the knock sensor to have detected a knock, but enough out of the range the knock sensor could reset engine timing, which the ECM read as a knock sensor out of range too.
I'd replace the coil, of course, then erase the codes and see if the knock sensor resets. They do go bad on AJV6s. I've seen a few now that they're getting higher mileage.
Old Nov 1, 2010 | 11:49 AM
Brogi's Avatar
Knock Sensor Control
The knock sensor control utilizes two sensors mounted directly onto the engine block. The objective is to limit the timing adjustment to the cylinders where knock is actually occurring, while allowing the others to continue operating normally.
One is under the intake manifold, the other is on the rear left side of the engine looking from the front attatched to the block
Old Nov 1, 2010 | 05:25 PM
steve11's Avatar
ud
Brogi,
Are you sure - we're talking about a NA 2.5/3.0 Gasoline engine, not a diesel. I've had both early and late MYs completely apart and only one KS sensor. I have experience with NA configurations, not Europe and we don't get diesels here, but I'm assuming that the diesel might be your reference to a second knock sensor. The other possibility is the AJV6 variation in the S-Type. It uses a left/right, but more like an upper left lower right knock sensor config. They OBD out under the standard P0327/8 P0332/3 protocols, but the LH is really under the intake manifold in a config similar to the X variation. But, all NA X variations only use the P0332/3 protocol for one sensor.
Old Nov 2, 2010 | 04:21 AM
Brogi's Avatar
Sorry Steve11, You are correct, it is the S-type that has 2 sensors, my mistake, thought this thread refered to s-type.
Old Nov 2, 2010 | 06:00 AM
steve11's Avatar
ud
No problem Brogi - Just wanted to make sure I hadn't lost my mind...which I do occasionally!
Welcome to the forums BTW. Good to have your technical expertise on board. In only a couple of posts I can tell you know your stuff.
All the best,
Old Nov 25, 2011 | 08:43 AM
03silverxsport's Avatar
Default same issue
i'm curious did this fix the issue? My 03 3.0 is throwing the same code P0322 Knock Sensor Bank 2 low Input. the car is acting very wierd. sometimes and not all the time at WOT or a high RPM shift it just bogs right down and acts like it's misfiring.
It also threw code C15AA which I'M guessing may be the DSC fault code? Everything i can find on this code says it's a manufactures specific code.
has anyone else had this problem? any help is greatly appreciated.
Kirk
Old Jun 23, 2012 | 12:44 PM
mathew's Avatar
Default v8 misfire problems
i could realy do with a bit of advice i have a 1998 jaguar xj8 soveriegn in the past six months i have had a few of problems it runs great when it is cold but once it gets warm it starts to have a misfire i put the odb2 computer on it which told me to replace the flowing a coil pack, four spark plugs a o2 sensor which is all on the o/s bank and now i have just replaced the coolant temp sensor i took the car for its mot and it failed on emissions the hydro carbon where through the roof. i would be greatfull if anyone would be able to help with my siuation.
Old Jul 1, 2018 | 11:55 PM
cemmixer1's Avatar
hello everyone my name is joey and im from pa I have a 2004 jag s type 3.0 that has the engine light on and from a dead start if I accelerate past 2000 rpm's the car starts bucking and knocking and if I come of the pedal it go's back to normal I already replaced the knock sensor 3 months ago and it started again but intermittently can anyone help and also are there 2 knock sensor's on this car?
Old Jul 2, 2018 | 12:18 AM
Dell Gailey's Avatar
This is X type (X400) forum. Try posting in the correct forum for S type.
Old Jun 8, 2021 | 12:56 PM
Furmanator10's Avatar
Default 06 x type knock sensor. Do I have to replace gaskets if I remove intake ?
Do I have to replace gaskets if I remove the intake ?
Old Jun 8, 2021 | 01:00 PM
Thermo's Avatar
Veteran: Navy
Furmanator10, do you have to, no. Should you? Depends. If you have not replaced the gaskets in the last say 5 years or so, then replacing them is going to be a good idea to prevent future issues. If you have replaced them recently, then I would not worry about it. If you are finding it hard to get your hands on the upper intake gaskets at your local auto parts store, ask them for the upper intake gaskets for the same year Lincoln LS 3.0L engine. The engines share a lot of components, one of which are the gaskets in question.
Old Aug 29, 2021 | 01:23 PM
OK Thanks
Old Sep 25, 2022 | 11:43 PM
Xeno's Avatar
EDIT: Sorry, I keep getting direct to other forums by search results. Ignore this.
I went to ebay to buy a knock sensor for a 2004 XJ8, but found many knock sensors of widely-varying prices, all claiming to fit my car:
KS305 Knock Sensor New for Jaguar X-Type S-Type XJ8 Vanden Plas XK8 XJR XKR
1811829 GPD Knock Sensor New for Jaguar X-Type S-Type XJ8 Vanden Plas 2004-2005
For 2004-2005 Jaguar XJ8 Knock Sensor SMP 79117JN 4.2L V8
For 2004-2007 Jaguar XJ8 Knock Sensor NGK 94722CF 2005 2006 4.2L V8
For 2004-2005 Jaguar XJ8 Knock Sensor Right Santech/ Omega Envir. Tech. 31675RX
Knock Sensor For Jaguar X Type S XJ8 XK8 XKR Super V8 Vanden Plas XJR FM82G4
GENUINE AJ84433 KNOCK SENSOR KS304 SU7013 5S5620 S8904 SBC3875 for JAGUAR
How am I to know which ones I can use?
Are the $136 ones really better than the $36 ones?
Old Sep 26, 2022 | 03:08 AM
Perhaps ask in the correct forum?
Old Nov 26, 2022 | 09:45 AM
lannyb's Avatar
Default Same issue
Recent replaced my knock sensor due to being in limp mode, now I am getting the code intermittently. Not sure what todo at this point has anyone found a resolution?
2006 jaguar x type 3.0 v6.
Old Nov 26, 2022 | 04:11 PM
astromorg's Avatar
When you fitted the new sensor did you clean the joint surfaces on the engine and the sensor with metal cleaner to ensure perfect contact between the two? Bolt should be tightened to 19Nm
