knocking sound
Old Sep 22, 2011 | 07:45 AM
MosDefXType's Avatar
Default knocking sound
i am hearing a knocking sound from the front passanger side. i hear this sound when i drive on bumpy roads. i recently replaced all shock absorbers. anyone ever had this problem before?
Old Sep 23, 2011 | 06:56 AM
baffourg's Avatar
I do but still trying to figure out what the problem is cos I have had the mechanic check it but everything seem fine, however the sound is still there esp on bumpy roads
Old Sep 23, 2011 | 08:21 AM
cujet's Avatar
Here's my best guess:
The front lower control arm has liquid filled bushings on the aft bushing. The liquid liberates itself over time (leaks) and then the clunking starts. The only solution that I know of is control arm replacement. Mine is doing this.
I've considered removal of the control arms, cleaning out the bushing's internals and injecting with silicone or 30 durometer polyurethane. Might ride stiffer, but at this point I don't care.
I found new control arms for $159 each. But, I think they are generic, not OEM Jag parts. Probably not with liquid filled bushings.
Old Sep 25, 2011 | 06:36 AM
baffourg's Avatar
I noticed oil dripping down one of the bushings once and I didn't know this meant that the bushing is gone. Anyway as you may gather by now, I live in Ghana where jaguars and more specifically Xtype are extremely rare, I may there have to order these parts from Europe or USA, question is what can I do in the interim to at least enjoy a comfortable ride whiles I wait for my parts to come in. Thank u
Old Sep 25, 2011 | 08:08 AM
I'm just shooting in the dark, but if you are talking about a long wait for parts, is there any potential for making a bronze replacement to get you by?
Old Sep 25, 2011 | 10:39 AM
baffourg's Avatar
tell me about it Norri
Old Sep 26, 2011 | 11:26 AM
cujet's Avatar
I do not think you will be able to machine a brass bushing to replace the liquid filled leaking bushing. The configuration does not lend itself to doing so.
I strongly suspect the liquid bushing can be perforated with a drill bit, cleaned out, and injected with synthetic rubber, or soft polyurethane,.or some other product that "cures" to a rubbery state. Then the part re-installed.
Also, you can find new lower control arms on the internet for a reasonable price.
Old Sep 26, 2011 | 02:19 PM
Adam Lueb's Avatar
Smile Knocking sound
I had the same sound last year. It turned out to be the bushings on the front and rear swaybars, The dealer wanted $800 to fix. I had a local mechanic do it and he charged me $200 including the price of the bushings. You might want to check the swaybars, if they twist or can be pushed up and down then it is your bushings.
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
carl purchase
Oct 14, 2015 06:14 PM
DFW
Oct 1, 2015 07:22 PM
Rocky15
Sep 28, 2015 04:59 PM
Long Islander
Sep 27, 2015 03:45 PM
