Lambda sensor removal help please!
Old Feb 22, 2011 | 03:25 PM
topanga's Avatar
Default Lambda sensor removal help please!
Hello everyone, I am in the middle of replacing the lambda sensor (post cat, bulkhead/firewall side). My lambda socket fits ok but no room to get a breaker bar in as it presses against the brake pipes. I have read somewhere on here that they had to bend spanners and weld sockets onto it. Just wondered if anyone had done the job and what methods and tools they used. On the plus side, the plug change has gone well . Thanks for any help.
Old Feb 22, 2011 | 04:01 PM
Brutal's Avatar
Lol now you know why that sensor pays 2 hours book time(not enough many times) try a pry bar against your 02 sensor tool
Old Feb 22, 2011 | 04:08 PM
topanga's Avatar
Tell me about it Brutal, when you say a pry bar against the lambda tool, how do you mean? Also what method do i use to actually turn the sensor, I can get the socket over the sensor, but can't get anything else to fit it? Thanks.
Old Feb 22, 2011 | 08:38 PM
Brutal's Avatar
I use an 02 sensor tool that slips over the sensor and wire and has a 2" extended piece to slip in a 3/8" ratchet. Good luck with that, I use a pry bar against that part and anything to pry against on the engine to crack it loose. Then take it out by hand. If your replacing the sensor, spray it with penatrant(never do that if your reusing the sensor cause the oil will damage the sensor since it has breathing ports to detect exterior 02 content for reliable operation).
Old Feb 23, 2011 | 02:53 AM
topanga's Avatar
Thanks for the info Brutal, much appreciated, the tool you use, do you mean something like this, but maybe with a longer extended piece?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...T#ht_783wt_698
The type I'm using now is this, but as you must know theres not a lot of room for it.
http://cgi.ebay.co.uk/DRAPER-EXPERT-...#ht_2718wt_754
The last one I thought of was this one, but I doubt I'd be able to get enough leverage on it.
http://cgi.ebay.co.uk/Laser-4257-Lam...f#ht_579wt_698
Jandreu
Jan 23, 2017 10:58 AM
KarimPA
Sep 12, 2015 08:15 AM
gregster41
Sep 6, 2015 06:51 PM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
KarimPA
Sep 3, 2015 07:32 PM
