Leaking hoses in the cold
Old Dec 15, 2008 | 12:43 PM
sugarcean007's Avatar
Default Leaking hoses in the cold
So I was driving home the other day and got stopped at a red light. I had the heat on 84 and noticed the car was blowing out cold air and not running up to par. I continue driving and I realize steam coming out of the engine, so i pulled over. It turns out, what i thought was a leaky hose, was really the piece that sticks out into the hose, and it was cracked. what do i do? Can this be fixed diy? Or should i take it to the dealership. The car is just parked outside my house, i kinda ghetto rigged it so where it doesnt leak anymore but i dont feel safe driving it.
Cean B.
[IMG]local://upfiles/3797/B7FDDD83184D4E26AF954181AB228BE4.jpg[/IMG]
[IMG]local://upfiles/3797/F504B47C9D65423B94C0961B79485A7F.jpg[/IMG]
[IMG]local://upfiles/3797/79FBD074365941259C6BCD27FED0A6F2.jpg[/IMG]
Old Dec 15, 2008 | 12:51 PM
Brutal's Avatar
Default RE: Leaking hoses in the cold
REPLACE THE COOLANT RESERVOIR, AND YES ITS OLNY AVAIL AT THE DEALER, BUT IF YOU MANAGED TO RIG IT, YOU CAN REPLACE IT TOO, ITS EASY
Old Dec 15, 2008 | 12:54 PM
Dennis's Avatar
ud
List price is $192.21 and dealers charge price if they install it $131.26 plus labor.
Old Dec 15, 2008 | 12:58 PM
So there isnt a website that sells the reservoir?
Old Dec 15, 2008 | 01:05 PM
Dennis's Avatar
ud
This place here..you should get a new cap too..don't forget to use only distilled water with 50/50 with the Jag coolant..
http://www.trademotion.com/partlocat...layCatalogid=0
Old Dec 15, 2008 | 01:14 PM
You guys never fail to help. Thank you so much. Now if only i had a jaguar mechanic in atlanta that i could trust...
Old Dec 15, 2008 | 03:36 PM
Brutal's Avatar
WHATS NOT TO TRUST ABOUT REPLACING THE RESERVOIR? BUT THEN AGAIN YOU COULD SLIP A SMALLER PLASTIC FITTING INSIDE AND EPOXY IT ALL TOGETHER WITH SOME GOOD PLASTIC EPOXY. THE ADDED PIECE INSIDE WILL ADD STRENGTH. i KNOW XTYPE OWNERS ARE ALWAYS TRYING TO SAVE MONEY
Old Dec 15, 2008 | 06:49 PM
310jag's Avatar
This is something else I've had to do to my car in the past couple of months. Mine developed a hair line crack on the bottom of the tank, which when hot, will expand and cause a major leak. I would strongly advise against trying to repair the plastic tank (even with a high quality epoxy), due to the constant expansion and contraction the tank goes through.
The tank is not a dealer only item. Many Jaguar parts suppliers have these. I bought mine from Welsh for $130. Install time was less than 5 minutes.
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
Bcrary3
Feb 21, 2023 04:29 AM
Jandreu
Jun 30, 2022 03:10 PM
OkieTim
Sep 8, 2015 04:48 PM
