locked glovebox
Old Jun 22, 2015 | 10:01 AM
RonnieJoe's Avatar
Default locked glovebox
I put the key into the lock on my glovebox and turned it to the right
and it locked and I can't get it to unlock, is there a certain way to get it
to unlock? 2004 2.5
Old Jun 22, 2015 | 11:25 AM
mrplow58's Avatar
If you haven't used it much, put a squirt of oil on the lock, and let it sit for a couple of minutes. Then try moving it back and forth about 15 times. Also try holding it closed while doing that. If it is still stuck try GENTLY!! tapping on the key, with it in the lock. That is about all I have for you. You use the same methods for outsice locks, and house locks......Good Luck....Mike
philwarner
28
Jul 11, 2017 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
