Long beep from backup sensor when starting
Old Jan 20, 2018 | 02:59 PM
wa3ra's Avatar
Default Long beep from backup sensor when starting
When I start the car, I'm getting a long single tone from the reverse sensors...nothing behind the, and not in reverse.
The reverse sensors are also not operating, but I believe that is a bad sensor issue.
Will a bad sensor set a tone like that at startup?
Old Jan 20, 2018 | 06:23 PM
avern1's Avatar
The long beep is to signal that you have a malfunction. It should quit once repairs are made to the system. If you have some one put the vehicle in reverse and you listen closely to each of the sensors they should have a clicking/ticking noise indicating the sensor is working. The bad one will be silent. Before pulling out the sensor check the wiring and plug for damage. Also the 2 farthest outboard are different from the middle ones.
Old Jan 20, 2018 | 08:45 PM
motorcarman's Avatar
You do realize that the Reverse Parking Aid module logs faults for you to help in diagnosing the problem!!!
bob
Old Jan 20, 2018 | 10:37 PM
wa3ra's Avatar
I had completely forgotten about that...and thought about it a little while ago. The iCarSoft read the codes...defective right outer sensor.
Since the old car is about 60 feet away, I'll bet I can steal the sensor from that car!
Thanks!
EZDriver
Jan 21, 2015 11:51 AM
Jon89
Jan 8, 2015 01:06 PM
StevePalmerUK
Aug 29, 2014 12:44 AM
KruBruder
Apr 21, 2009 12:01 AM
bojangles
Dec 27, 2007 06:39 PM
