Lost jaguar locking wheel nut key removal a b c d e f g h k l m n s t u v........
Old Feb 19, 2026 | 03:36 PM
  #121
OmarBorto's Avatar
Do you have any idea what code could this be? Thanks!
Old Feb 19, 2026 | 03:37 PM
  #122
OmarBorto's Avatar
Old Feb 19, 2026 | 11:21 PM
  #123
mikefarnham's Avatar
Good first picture Omar. It will help you to get better definition on where the tops of the left and right hand lugs/ears start as they are the least well lit and you will need to know which is bigger! If you do another to show this I will point you in the right direction but please be aware that some keys are very similar an, on occasion, it is only possible to narrow down the options to two or three of the 20 keys. This is not the end of the world as, even if you have to buy a couple they are easily resaleable and, almost noone ever replaces their lockers so can sell all of those they buy. Hope this helps, Mike.
Old Feb 20, 2026 | 02:46 AM
  #124
OmarBorto's Avatar
Thanks Mike, really appreciated. Here you go with a new photo, hope this helps.
Old Feb 20, 2026 | 04:57 AM
  #125
Much better picture Omar. i am just about to message you with next steps.
Good luck. Mike.
Old Feb 20, 2026 | 07:18 PM
  #126
Peter_of_Australia's Avatar
Apologies, if my reply here would not make sense for someone, who read thru all 7 previous & ancient pages of posts - I did not. I just read the few posts from yesterday. And seeing that issue, I think it should be possible to remove the lock-nut (where the key is missing) with a Bolt Nut Extractor. You can find one of those sets e.g. on Aliexpr.. First apply penetration spray, though. And then use a new lock-nut, for which you have the key.
PS: Obviously, ideally you would also need something like an air-powered (or other) impact driver for those extractor sockets... But it could possibly work to hammer the tool onto the lock-nut and use a simple ratchet or solid lever.
Last edited by Peter_of_Australia; Feb 20, 2026 at 07:23 PM. Reason: Added PS note
Old Feb 27, 2026 | 03:04 PM
  #127
Ronks2's Avatar
Back in the day we would take a 12 point craftsman chrome socket and bash it on, then spin it off.
Old Feb 27, 2026 | 03:31 PM
  #128
These lockers are tamper proof in that the top halves spin independently from the bottom which they overhang making this method ineffective on these domed lockers.
There are other ways and means which are an awful lot of effort and could damage the wheels so, in the end it is advisable to get the correct key if possible. Mike.
Old Mar 5, 2026 | 12:07 PM
  #129
Matt Faz's Avatar
By chance. Do you have a H for sale? 😂 i left mine on my wheel one tired afternoon and now I need new brakes and cannot find it!!
Old Mar 5, 2026 | 02:13 PM
  #130
Keys are usually readily available on Ebay. Suggest searching for words to the effect of: Jaguar locking nut key H.
Please note that key H is probably the most likely to distort of the 20 available due to its design shape. For that reason a key may not easily fit onto your nuts and may need persuading if you are unlucky. For that reason I have three different key Hs in my master set so that I can always find one that fits easily.
Hope this helps.
Mike.
Old Apr 4, 2026 | 03:28 AM
  #131
M Qazi's Avatar
Default Lost nut key code "A" possibly.
Hi I was just going through this discussion thread and was hoping if someone could help me out finding the locking nut code as I am desprately in need of one to unlock the wheels and have the tyres replaced as they are reaching the minimum tread limit.
Just for the information, I managed to take a picture of the nut shape and found that there are four slots and each of them at equidistance on the circumference of the nut.
Thank you.
Old Apr 4, 2026 | 03:51 AM
  #132
If the four slots are equidistant and the four lobes are exactly the same size and the nut has four way rotational symmetry it is DEFINITELY key A you need.
Hope this helps.
Mike.
Old Apr 4, 2026 | 03:55 AM
  #133
Have sent you a visitor message in case of further questions.
Mike.
Old Apr 4, 2026 | 03:57 AM
  #134
M Qazi's Avatar
Not sure about what visitor message is. I am new on this group.
Old Apr 4, 2026 | 03:59 AM
  #135
M Qazi's Avatar
Would you be able to send me through, if you have one or if you know where can I get it from?
Thank you
Old Apr 4, 2026 | 04:05 AM
  #136
M Qazi's Avatar
Each slot is facing each other at same tragecetory. Hope this will further clarify what the actual Code is.
Old Apr 4, 2026 | 04:12 AM
  #137
You can access your messages from the bell icon near the top right of page by your avatar and the gear wheel icon.
RaceDiagnostics
Aug 18, 2023 01:04 AM
bryans
Jul 3, 2013 05:54 AM
markoscar
Jan 27, 2013 07:10 PM
engsnayl
Aug 22, 2012 08:32 AM
