Loud Buzzing Noise When Trying To Start
Old Mar 26, 2015 | 04:31 AM
jockavelli's Avatar
Default Loud Buzzing Noise When Trying To Start
Hi Guys
Just joined and really hope someone can clarify my issue.
This morning my 2004 x-type 2.0 Diesel wouldnt start on the first 2 attempts, 3rd time was the charm and all was good.
Once the coil light had gone & turned the key only for there to be a loud buzzing noise but no attempt of the engine to actually start, this happend twice.
Once it did start the car was prefect!
However once i got to my work i turned the car off, waited a few moments & tried again, only for the exact same issue to happen.
But again on the 3rd attempt it started perfectly....
What is going on?
How difficult is this to sort?
Old Mar 26, 2015 | 08:26 AM
amcastro1's Avatar
Hi.
I do not have experience on diesel engines, but my 3.0 petrol did the same thing. I corrected it by changing the battery. check the voltage on your battery and also if it is more than 5 eyears old, change it regardless of the problem you have.
Regards
Old Mar 27, 2015 | 08:03 AM
jockavelli's Avatar
Ok so i had the battery checked & all is good with that.
I've had no problem since lunch time yesterday, the car starts first time every time & drives perfectly, so im pretty stumped as to what the issue was.
Old Mar 28, 2015 | 01:49 AM
FollowMe's Avatar
I've had no problem since lunch time yesterday, the car starts first time every time & drives perfectly, so I'm pretty stumped as to what the issue was.
I would too have said the battery. I (again with my petrol) had this happen, My cousin who is a Jaguar approved mechanic came to look at it, the diagnosis was the battery. You may find that it doesn't happen again but if it does I would recommend that you replace the battery as it will more than likely remove the problem long term.
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
robiwhan
Sep 4, 2015 10:43 AM
innzane
Sep 2, 2015 10:08 AM
