"Low brake fluid " warning
Old Oct 2, 2014 | 10:46 AM
Johnde's Avatar
Default "Low brake fluid " warning
Hi, just acquired a 2003 x-type with 65,000 miles, and the dealer was supposed to have this warning corrected , as the fluid is fine. Also the ebrake red light is always on. He had his mechanics try to fix but after several attempts , they are unable , they are not jaguar mechanics. They did change the plug that goes into the fluid case, and I had a friend try to bypass, or short the plug to turn the light off, but that did not work, if anyone had a DIY fix, I would greatly appreciate . Thanks
Old Oct 2, 2014 | 12:18 PM
3lvis's Avatar
E-brake light is lit if you have a low brake fluid level, so if you sort that out it should go out, if not then check the e-brake switch. As for low brake fluid if you put those 2 pins together and it didn't go out then check that you have ground on one pin. If you don't have ground then there's your problem, if you have ground then you should have damaged wiring somewhere.
Old Oct 7, 2014 | 10:52 PM
Johnde's Avatar
I followed the wires leading out of the brake fluid container , and I don't see any signs of a short, do I have to have this rewired ?
aholbro1
Dec 29, 2024 06:46 PM
Jpav27
Jul 31, 2022 06:43 AM
giandanielxk8
Sep 6, 2015 07:21 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
