Low Cost Preventative Maintenance
Old Oct 24, 2010 | 07:50 PM
Mayor111's Avatar
Exclamation Low Cost Preventative Maintenance
Hey Guys,
Since I am new with Jags, and I have had mine for about 3 weeks, I wanted to share some minor, LOW-COST preventative maintenance you can be doing to stay ahead of any mechanical nightmares. I did these items mostly for peace of mind and because I want my Jag to be trouble free:
1) IMT O-Rings: They cost me $3.50 each (2 of them needed) and I replaced them myself in 20 minutes - fixed a major vacuum leak I had which set off my CEL.
2) Cabin Filter & Air Filter: Cost me $26 for the Cabin and $14 for the Air. Keeps the air to the cabin fresh and the other keeps unblocked airflow to the engine... Installed both myself in less than 30 min.
3) Fuel Filter: Cost me $11 for the part, and $22.50 to have it installed (I didn't know what to do, so I paid someone). Keeps clean gas going to the engine.
4) Serpentine Belt: Cost me $135 installed (which may or may be considered "low cost") You definitely want to have this belt checked out every few oil changes. It controls so many systems, so if it breaks, you will be stuck on the side of the road over-heated. A tow will cost you about $100 to $150 so why not just put that toward a new belt...?
5) Coolant Flush: Cost me $70 to have the Coolant drained, more Coolant added, then drained, and then refilled. Now is the PERFECT time to do this because it should be done before winter for added protection.
6) Transfer Case: Cost me $89 (a special at Aamco) to have the TC oil drained and refilled. With this being the weakest link for the X-Types, I want to do anything I can to keep it lubricated.
So if you are new to owning a Jag, or you are like me, a person who doesn't always focus on car maintenance...you could do these simple jobs to really maintain your Jag well...
If I missed any TO DO items that are either "EASY" or "LOW-COST", please do share them here...
Old Oct 24, 2010 | 08:17 PM
mohrd's Avatar
Good plan Mayor
Old Oct 25, 2010 | 10:42 PM
Disco stu55's Avatar
Great plan.
Old Oct 28, 2010 | 01:30 PM
krisleslie's Avatar
Isn't Coolant Flush snake oil?
Old Oct 28, 2010 | 01:32 PM
krisleslie's Avatar
Oil change and the Fuel Filter (never done them sorry)I think was also easy both only have one bolt if I remember correctly and that saves a bit of money.
Forcedair1
Sep 8, 2025 01:57 PM
Wolfy
May 28, 2024 08:06 AM
tomsjag
Jun 10, 2023 10:02 AM
calviroman
Sep 21, 2015 06:04 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
