Low washer fluid warning staying on?
Old Nov 29, 2012 | 09:16 AM
Rigsby94's Avatar
Default Low washer fluid warning staying on?
I have a 2004 X Type and the Low Washer Fluid Light is staying on. I filled it all the way up as it wasn't really that low in the first place but still stays on. Is there a sensor that can be clean or checked in the washer tank? Or could it be something else?
Old Nov 29, 2012 | 10:06 AM
There's a level switch (see item 6) in the side of the Reservoir:
Check for power or a loose connection and whether it needs cleaning before assuming a replacement is required.
Old Nov 29, 2012 | 10:27 AM
henry k's Avatar
By coincidence, just last week, I had a problem with the indication NOT coming on.
I took this photo during my investigation.
The sensor is the the middle unit ( which just pulls out).
I assume the top unit is the washer pump ( which is not very clear in the above diagram but is item 5 ).
Access requires, on my car, ONE screw securing the outer edge of the wheel arch liner, a couple of screws lower down by the side of the engine bay and then easing the liner out of the way.
There is another very recent thread on this.
I just pulled the sender part way out and when I pushed it in again it had corrected the problem.
Old Nov 29, 2012 | 04:29 PM
Rigsby94's Avatar
Ok thanks for the help I will check that sensor.
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
Jpav27
Jul 31, 2022 06:43 AM
johndahlheimer
Sep 16, 2015 05:44 PM
giandanielxk8
Sep 6, 2015 07:21 PM
