Lowering and stiff suspension i need help..
Old May 9, 2013 | 03:12 PM
Gordonfrs's Avatar
Default Lowering and stiff suspension i need help..
Hello... I just bought new 19 inch rims for my jaguar x type and I have a problem bcos the tires have friction and are destroyed at the edge, so I decided to lower it and stiff my suspension but I only know I need springs... So can u tell me what is the best to lower it and stiff my car, but not to expensive )) many thanks
Old May 9, 2013 | 10:45 PM
Justink201's Avatar
if your tires already rub, lowering the car will probably only make it worse. What size tires are you running on the 19s?
Old May 10, 2013 | 07:21 AM
Gordonfrs's Avatar
I mean The Wheel arch is hitting my tyre when i hit a bump or put hole the arch is cutting into the edge of my tyre so that is why I need to stiffen... And the the tyre is 235/35/19 so pls tell me what parts I need to do it, lower it and stiffen...
Old May 10, 2013 | 06:27 PM
Justink201's Avatar
I'm running 245/35/19s on mine and lowered it with KW coilovers but I had to do a LOT of work with a fender roller to get it to stop rubbing. I don't think lowering your car, even though it could stiffen the suspension, will stop it from rubbing, I think it would only make it worse.
Old May 15, 2013 | 05:03 AM
Aamir's Avatar
Sounds like wrong offset wheels.
As the gentleman above said, lowering & stiffening WILL make it worse.
Forcedair1
Feb 19, 2020 01:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
duecedriver
Dec 25, 2015 11:47 AM
08Z06
Oct 24, 2015 05:46 PM
redgear
Sep 18, 2015 10:05 AM
