Manual 5th gear.
Old Dec 13, 2017 | 05:17 PM
Blindman's Avatar
Default Manual 5th gear.
I was driving to work the other day and all of a sudden it kick it self out of 5th gear. It did it several more times on the way. I was wondering since I did a motor swap in this car is it possible something has come loss? It's a 2002 xtype with 5 speed manual 3.0 liter. It did pull the exhaust out of the real muffler connection the day before but I don't know if that is related in anyway. Thank in advance for the help
Old Dec 13, 2017 | 07:37 PM
Thang Nguyen's Avatar
Do you have cruise control? Is that happen when cruising? May be I'm wrong, but it could be relate to speed sensor.
Old Dec 13, 2017 | 07:43 PM
Blindman's Avatar
It's a manual transmission. It moved the shifter out of gear. And no cruise was not being used
Old Dec 14, 2017 | 05:18 PM
avern1's Avatar
As i understand it. You are cruising along and it pops out of gear. You also stated that the exhaust has come loose. It sounds as though you have a motor mount issue or the bolts on the engine anti-roll link have come out. A quick check is with the hood open and the engine running hold your foot on the brake and try to accelerate in gear. Is the engine lifting abnormally high.
the beagle
Nov 2, 2012 04:37 PM
Moe-she-sa
Dec 21, 2011 08:52 PM
85_305
Dec 8, 2009 06:52 AM
Jaimejames
Sep 29, 2009 05:09 PM
dougs02
Feb 18, 2008 09:04 AM
