Misty windows and aircon not cold
Old Dec 3, 2021 | 06:16 AM
Slownot's Avatar
Default Misty windows and aircon not cold
Windows are constantly misting up badly and struggle to get rid of, aircon also is not getting down to cold the temperature does drop but not to expected air con chill, any ideas? Coincidence?
Old Dec 3, 2021 | 01:34 PM
sov211's Avatar
Clearly, you need the refrigerant renewed. The two symptoms are definitely related.
Old Dec 5, 2021 | 08:05 AM
MeatBag's Avatar
A few years ago my 2003 X-Type AC stopped working.
My first thought was it needed to be recharged with coolant.
My mechanic checked the system - it was fully charged and not leaking.
I researched here on the Forum, and found the attached TSB.
Basically it has you remove the AC Compressor valve and spring - and simply re-insert them in reverse order. What? I was skeptical too....
But since the other common problem seems to be the airbox door actuators buried deep in the dash, and this valve/spring reversal was quick and easy - I had my mechanic try that first - and it worked.
AC was nice and cold again - and it kept on working until I sold the car in 2018.
Old Dec 5, 2021 | 12:56 PM
motorcarman's Avatar
A MY would be nice.
TSBs from the ancient past.
File Type: pdf
Old Dec 5, 2021 | 02:35 PM
Mr rx-7 tt's Avatar
I would bet this is his problem.
I was having that issue some years back, went to the dealer and ordered the new O-ring and did the job myself. Fixed the war air issue.
Old Dec 22, 2021 | 10:21 PM
Adrian462's Avatar
Hi. I am battling with my X type aircon, which fails to get cold enough. In the past 18 months, it's had a new compressor, been checked twice for refrigerant and it full. By chance, I came across your post and read with interest. My question is, can the mod be done without dumping the system or can you do the job on the compressor without losing refrigerant?. All stepper motors and doors work correctly.
By the way, this is my first real post on this site...joined some time ago but have just been stalking...a lot of my questions have been answered with other posts.
Old Dec 22, 2021 | 10:35 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...ng-mod-116762/
SEARCH is a marvelous tool
But....but...you say you replaced the compressor?
zmoothg
May 21, 2017 11:31 AM
motomental
Aug 16, 2013 06:55 PM
MDJag
Feb 20, 2011 08:49 PM
MK 82
General Tech Help
May 6, 2010 11:37 PM
