Mod lights
Old Mar 31, 2017 | 10:25 PM
Dell Gailey's Avatar
Default Mod lights
Trunk (I can see now), footwells. Next is LED strip under hood (same reason, so I can see).
Attached Thumbnails Mod lights-20170331_203911.jpg   Mod lights-20170331_203945.jpg
Old May 3, 2017 | 11:28 PM
Default New update
Engine bay = I can now see!!
Attached Thumbnails Mod lights-20170503_190239.jpg   Mod lights-20170503_212215.jpg
Old May 4, 2017 | 06:29 AM
Gophat's Avatar
That is super cool. Where did you get the strip l.e.d from?
Old May 4, 2017 | 11:49 AM
From here =
Then bought a door hinge pin, drilled a small hole just to the rear and slightly right (looking from front of car towards engine bay) of the driver's side adjustable hood height pad in front of the fuse box. Ran power through small drilled hole in fuse box, up under the slight protrusion of driver's fender to lights, return ground from lights to door hinge pin for hood close light cut off. Checked mounting height of pin with a little molded piece of "play dough" to assure mounting height.
Old May 4, 2017 | 12:08 PM
Pics
Attached Thumbnails Mod lights-screenshot_2017-05-04-10-58-31-1.jpg   Mod lights-20170504_110141.jpg   Mod lights-20170504_110055.jpg
Old Jun 21, 2017 | 10:45 PM
More lights =
Old Jun 22, 2017 | 10:48 AM
wa3ra's Avatar
Guten Morgen! Let loose the lumens!
I like it!
Old May 19, 2018 | 11:50 PM
Added DRL lights =
