My Jaguar won't start
Old Aug 21, 2009 | 04:29 PM
Thermo's Avatar
Veteran: Navy
jazzfans, the car will not run if you jump across the small and big leads on the starter. This is due to the ignition key being out of the RUN position and this will cause the ECU to not be energized, therefore no spark.
As for your problem, it is most likely a problem with your starter relay in the engine bay fuse box. If that doesn't fix it, then you are probably looking at a bad wire between the relay and the starter.
Old Oct 9, 2009 | 12:28 PM
nickbobby's Avatar
Default Could be the same
Does the engine start if you short the relay socket for pins 3 and 5 with the ignition switched on?
I guess take care she doesn't take off and push you through a wall!
BrentGardner
29
Dec 16, 2024 12:13 AM
jdzubas
Oct 4, 2015 09:14 AM
1964Daimler
Sep 2, 2015 11:41 PM
Drew2006
Aug 28, 2015 04:22 PM
Terrance Williams
Aug 26, 2015 11:50 AM
