Need ACM
Old May 6, 2015 | 08:07 AM
Howard1972's Avatar
Default Need ACM
I have a 2003 xtype and would like to play my iPhone through stock radio..jag dealer in Cincinnati wants 700 bucks..is there an aftermarket ACM..
Old May 6, 2015 | 03:08 PM
euanT's Avatar
They do come up on Ebay every so often(in UK anyway) or get a parrot kit like this:
Home / Parrot Shopping / USA
Old May 7, 2015 | 06:18 AM
Howard1972's Avatar
Thank you sir
Old May 7, 2015 | 03:25 PM
euanT's Avatar
You are more than welcome!! every little helps!!
Old May 9, 2015 | 09:09 AM
flyrr100's Avatar
This is the part # for the X Type ACM. C2C 40513.
Keep checking ebay, or check your local Jag dealer. There are some still around. Look to pay around $400-$450.
If you find one they are an easy install. You'll have to remove the center consol, which can be tricky.
I have a Sirius radio fed through the RCA jacks in the ACM set up.
Good luck.
Old May 10, 2015 | 06:14 AM
Howard1972's Avatar
Good luck.
Thank you for that..I really did not wanna spend that kinda money but it is looking like I may have too..
Old May 14, 2015 | 02:16 PM
flyrr100's Avatar
http://pages.ebay.com/link/?nav=item...d=281692290886
This guy want a lot.....
Old May 15, 2015 | 03:27 PM
dalippy's Avatar
Default acm
i researched the acm..far too expensive..i bought a good quality in car fm 12v modulator from evilbay..its pretty good..has a built in ground loop supressor so cuts any noise..i also got a boostaroo ..small inline amp for low levels ..as mp3s can be sometimes too low.
there was the option of an aftermarket stereo but a guy i work with fried the ecu dickin around putting in the new stereo ..had to get jaguar reflash the ecu..although he is a bit dumb.and im an electrician by professian..i went with veba fm modulator in the end
Old May 21, 2015 | 11:32 AM
veffremov's Avatar
<self promotion>
Check my ACM replacement:
https://www.jaguarforums.com/forum/a...ptical-134964/
</self promotion>
flyrr100
Sep 18, 2015 06:31 PM
Kristian_TT
Aug 28, 2015 02:32 AM
jahummer
Audio/Visual Electronics
Jan 17, 2009 01:39 PM
ajv_xj8l
Sep 9, 2008 11:50 AM
