need a can bus expert advice
Old Mar 21, 2012 | 08:15 AM
ace911emt's Avatar
Default need a can bus expert advice
my wife washed the car now i have a can bus failure // where should i look for water intrusion in the harness or connecters // see shifter problem for more of the story/// i am stumped and the dealer cant look at it for a week ... in a week i could fix it or burn it. help
Old Mar 21, 2012 | 08:35 AM
Brutal's Avatar
Xtype can suffer from water coming down the windshield and into the air box cavity and onto/into the ecu connectors. This is most likely if truely from washing and not just a coincidence. Pull connectors, clean and dry with eletrical conatact cleaner, reassemble and hope for the best
Old Mar 21, 2012 | 11:22 AM
Jagking's Avatar
check ecm connectors or in left side kick panel area arount the tcm
Old Mar 21, 2012 | 01:33 PM
ace911emt's Avatar
Default dry/cleaned
ecm connection clean and dry/thanks to my buddy with a 5 star anti tamper socket / checked and cleaned l/s kik pannel connections /i can read the ecu functions on the scaner but no commucation with can bus
Old Mar 21, 2012 | 05:09 PM
Jagking's Avatar
check for blown fuses
Old Mar 21, 2012 | 08:58 PM
austinmartus's Avatar
Did she get the j-gate excessivly wet cleaning the interior? When ever we get a new detailed they usually fry a jgate in the first month and it can cause a can fault.
Also the previously mentioned tcm or possibly abs module if cleaned under the hood.
Old Mar 22, 2012 | 10:57 AM
ace911emt's Avatar
does the can bus make a connection in the drivers side door (lock window swich) she washed down the door /if so this could be it
mikiep
Dec 20, 2019 07:37 PM
04Xjrsteve
May 7, 2019 04:06 PM
workworkwork
Oct 23, 2015 10:26 AM
adam699
Oct 13, 2015 05:53 PM
