newbie needs help
Old Sep 27, 2010 | 11:51 AM
Adam Lueb's Avatar
Smile Transfer case
Originally Posted by Thermo
Adam, when needing to repair a leaking oil pan gasket, one of the bolts for the oil pan is tucked up behind the support bracket for the transfer case. The only way I have heard you can get this bolt out is to: 1) drop the transfer case (lots of hours and tons of interference to get moved out of the way, therefore drives the cost of the repair sky high) or 2) you drill a hole in the bracket just big enough to slide the bolt through.
Thanks, interesting fix. I know in certain metals parts holes are stamped into them to give them strength. As I said stamped and not drilled.
trickeyM
Feb 29, 2020 07:00 PM
Marka
22
Sep 11, 2016 12:09 AM
Msteiner
May 16, 2016 12:19 AM
Clare Jennings
Oct 4, 2015 05:43 PM
ftypefan
Sep 25, 2015 12:14 AM
