No Air Cond wife is angry not good for me
Old Jun 12, 2022 | 10:54 AM
bsera44's Avatar
Angry No Air Cond wife is angry not good for me
2005 X Type Wagon No Air Cond Compressor clutch not engaged Checked relay power at terminals power there until relay plugged in then power goes to 0 volts. Relay works when checked with 12 V. jumper clutch term in Brkr box clutch engages but no cooling High press ice cold low press line cool
Old Jun 13, 2022 | 10:00 AM
RBaczek's Avatar
When you jump the relay (pressure switch), does the clutch engage? If so, check your R-134A (refrigerant) level with an A/C gauge. When the refrigerant is low, the relay won’t allow the clutch to engage.
hook up the gauge to the low pressure side of the a/c lines, jump the a/c pressure switch to engage the clutch. If it’s low, recharge per manufacturer’s recommendation
Old Jun 13, 2022 | 01:33 PM
All Cattle No Hat's Avatar
Same exact car here, and also no AC but I'm far more ignorant as to what to check and how. I'm at the point where I can be parked with the engine running, hit the AC button and notice the engine rpm change slightly but no cool air. A very basic tutorial on how to get to the point of at least the first poster would be very helpful. I can go buy a tool if need be. Thank you. (I'm not mechanically uninclined, solved my own intake code issues and replaced the entire suspension. Electronics are my weak spot so far.)
Old Jun 13, 2022 | 04:03 PM
motorcarman's Avatar
Jaguar issued a TSB years ago.
File Type: pdf
Ena_ii
Aug 30, 2017 11:05 PM
thinman
Jun 8, 2017 03:14 PM
jag4me
Jul 3, 2014 01:53 PM
prrthdtx
Nov 24, 2010 08:01 AM
Smeghead
Aug 15, 2010 04:35 PM
