no bass
Old Nov 29, 2007 | 04:00 PM
aquill1's Avatar
Default RE: no bass
Adjust through the factory radio...there aren't any adjustments on the factory amp...welcome btw!
Old Nov 29, 2007 | 04:34 PM
nineball's Avatar
Default RE: no bass
factory system sucks! make your own!
Old Nov 29, 2007 | 05:19 PM
Cadillac's Avatar
Default RE: no bass
[:-]This is what I call a sub lol
Old Nov 29, 2007 | 05:52 PM
aquill1's Avatar
Default RE: no bass
What kind of amp is that?
You'll be better off swapping out what is already in there and adding an aftermarket amp.
Old Nov 30, 2007 | 08:58 AM
aquill1's Avatar
Default RE: no bass
He did all the box fabrication on his own. I think he had someone else do the leather but I'm not sure...I'm pretty sure he kept the stock head unit. Were you wanting to swap out your stock radio for a different one?
Old Nov 30, 2007 | 11:22 AM
nineball's Avatar
Default RE: no bass
it's amazing what happens when you look back overthe messages for the last year. you can find all sorts of good info and ideas of things people have done already.
https://www.jaguarforums.com/m_9591/tm.htm
Old Nov 30, 2007 | 08:54 PM
aquill1's Avatar
Default RE: no bass
Hey nineball do you ever read what I write? What kind of amp do you have?
Old Dec 2, 2007 | 08:23 AM
aquill1's Avatar
Default RE: no bass
So you are using a bigger amp but still the stock sub? Did you use the stock wiring or add some thicker awg?
Old Dec 3, 2007 | 09:19 AM
xtyperick's Avatar
Default RE: no bass
Bruce,
The power you are talking about in the trunk, is it the source you can buy the 12V power outlet for? If it is, how did you find the rating of 30A? I bought the kit and it had a 7.5A fuse in it. The wire looked to be ~ #12.
Old Dec 4, 2007 | 03:39 PM
aquill1's Avatar
Default RE: no bass
Thats sweet bo! I was wondering how you figured out that this was back there! Is it back there for every x or just ones with premium sound system? If you end up wanting a different 6 or a couple let me know I'll see what I can do for ya...Any pics?
Old Dec 5, 2007 | 01:07 PM
xtyperick's Avatar
Default RE: no bass
Bruce,
If you want to try a single 10" in the rear deck, I have a stencil I used to make a mount for mine. I used the factory sub mounting on the rear deck so It fits cleanly up underneath. A sub box will always sound better but you lose trunk space. When we travel I pull the box out, use this and it still sounds pretty good...and a lot better than the factory.
Let me know if you want a copy of the stencil...and be ready to look for rattles.
italianjobtony
XJ40 ( XJ81 )
Apr 5, 2016 08:23 PM
damienedwards
Nov 22, 2015 10:51 AM
Rocky15
Sep 28, 2015 04:59 PM
Zarro
Sep 24, 2015 08:34 PM
Darrenmb
Sep 9, 2015 09:31 PM
