No High Beams, Blikers or Hazzards
Old May 8, 2025 | 05:52 AM
Hankthebald's Avatar
Default No High Beams, Blikers or Hazzards
I have a 2004 Jaguar X Type. I just lost my High Beams, Blinkers, and Hazzard lights. They all wen out at the same time and are totally out not intermittent. My searches keep contradicting each other and I am wondering if there is a place I can get the correct electrical schematic.
Old May 8, 2025 | 07:45 AM
Peter_of_Australia's Avatar
Have a look here - sounds like F29:
https://www.jaguarforums.com/forum/x...-module-88042/
And this is the schematic - looking at this, other options would be a faulty ground connection or a problem with the general electronic module:
Old May 8, 2025 | 05:26 PM
Thermo's Avatar
Veteran: Navy
Hank, before we get too far into the schemeatics, we need to answer a key question to make sure we get the correct diagrams for your car. In 2004, Jaguar updated the X-Type. Part of this involved re-numbering the fuse boxes and also changing around some of the circuits. So, do you know if you have a pre-March 2004 car or a Post April 2004 car? If you are not sure, look in the driver's door jam and you wlll see a sticker there (near the door latch) and that will have the build date on it.
Peter is on the correct track in that it most likely is a fuse powering the GEM module (controls all the basic electronics inside your car), but if you also notice that you have wet carpetting after going through a car wash or when it rains (more than what would just be on your feet), then you may have a bad GEM module.
Old May 11, 2025 | 09:26 AM
My car was made early 2004 so it would be before the change.
I have not had any water inside the cab so it is unlikely the module got wet.
I am also looking for a fuse box diagram. Nothing is numbered on my fuse box and I have tried to look up diagrams but get conflicting information.
Old May 11, 2025 | 05:37 PM
Thermo's Avatar
Veteran: Navy
Hank, if you can wait a week, I will send you the diagrams that you need. I am on travel, so, I do not have all my manuals with me. Send me a PM with your e-mail addy and I will send you the diagrams as soon as I get home.
Old May 16, 2025 | 06:48 AM
Is the GEM module also referred to as a BCM.
Old May 16, 2025 | 07:10 AM
My 2004 X-Type is an after-changeover-X-Type, hence, I have send you above the info I have regarding that one. But if yours is just earlier, here is the fuse info of 2002-2004 X-Type:
baudrate
Aug 23, 2025 08:53 PM
Kyd
16
Jul 3, 2016 09:58 AM
cybercg
Sep 30, 2013 03:43 PM
tvn300
Feb 13, 2010 07:48 AM
