No kickdown car splutters on acceleration
Old Sep 22, 2017 | 03:12 PM
johnkent's Avatar
Default Kickdown / Acceleration problems
Am having problems with my x types Kick down the car splutters there's no acceleration and going up hill , well it won't
Engine idles fine revs fine doesn't seem to misfire no Engine warning lights up
X type 2.0 v6 sport 2003 65,000 miles
Anyone got any ideas
Old Sep 22, 2017 | 06:06 PM
Doug's Avatar
Clogged fuel filter?
Old Sep 23, 2017 | 01:53 AM
JagV8's Avatar
Though it could be misfires - the car will normally back off long before you feel or hear them.
Worth a check for pending codes.
BTW, wrong sub-forum.
Old Sep 23, 2017 | 03:33 AM
johnkent's Avatar
Thanks lads
i'll try fuel filter
was also thinking misfire
i will try my code reader to see if any are stored
is it difficult to replace fuel filter and spark plugs ?
cheers
Old Sep 23, 2017 | 05:32 AM
iownme's Avatar
possibly the throttle body needs to be removed and cleaned
clean mass air flow sensor
keep driving hard until it gives u a check engine code
Old Sep 23, 2017 | 06:13 AM
johnkent's Avatar
Just one thing when i bought the car it was low on petrol, light was on, i put £10 in and light is still on , theres no leaks, i'm wondering if its sucked up some dirt from tank, if it was gearbox ( auto) would i get an engine light come on if there was a fault with it?
Also how involved is it to change fuel filter and plugs
Old Sep 23, 2017 | 08:41 AM
johnkent's Avatar
13 codes logged cleared them off and 2 remain wont clear
code 1108 and 1000 pending
but 1108 stored when running
anyone shed any light on this
Old Sep 23, 2017 | 08:52 AM
johnkent's Avatar
Heres the 13 that were logged
0306
1314
0102
0112
0341
0346
1108
1549
1646
1647
1603
1000
1108
Only 1108 and 1000 remain they wont erase
Old Sep 23, 2017 | 09:00 AM
Dell Gailey's Avatar
P1000 = ignore = incomplete drive cycle (after clearing codes)
P-1108 =
P1108 EMS
OBD II
MAP Sensor sense circuit
high voltage
Ignition ON 10 seconds 2 N ECM Default:
– Default value of 1.013 BAR
(29.92 in hg) used
PI1
-127
MAP Sensor sensor ground circuit (to splice):
open circuit
MAP Sensor to ECM sense circuit:
short circuit to high voltage
MAP Sensor failure
Posting in these forums =
Old Sep 23, 2017 | 09:50 AM
johnkent's Avatar
Would this cause no kick down acceleration and a complete failure to go uphills ?
Found the Map sensor cleaned it plugged it back and bingo no code, lets see how it drives next
Old Sep 24, 2017 | 04:32 AM
iownme's Avatar
a sticking flap in the throttle body caused by carbon buildup is a likely cause.
remove throttle body.
clean with the appropriate cleaner and replace.
Old Sep 24, 2017 | 05:00 AM
johnkent's Avatar
I'll have a look at throttle body next week
now the Map sensor has been cleaned I don't get the code anymore but EML Led doesn't work
Would a dodgy Map cause above symptoms
just a few more things
the remote key fobs won't unlock
they lock / boot release and lights button work tried the ignition flap that's ok
it won't pair the fobs with car either
also drivers seat electrics don't work
are these common faults ? And easily fixed
Old Sep 24, 2017 | 09:00 AM
Alfadude's Avatar
Probably best to start new threads if you are having other unrelated issues to allow you to get quicker and better responses to those issues.
Old Sep 24, 2017 | 01:11 PM
iownme's Avatar
fuel filter is easy, 5 minutes
spark plugs are a pain as intake and other stuff has ro be removed to access them. takes about 2 hours the first time
