No reverse after tranny fluid....HELP!!
Old Jul 30, 2011 | 02:21 PM
queenmb's Avatar
Default No reverse after tranny fluid....HELP!!
Please tell me this can be fixed. Ill try to make this long story short. Took 02 X in to have the leaking oil pan gasket and cracking drive belt replaced. While there they drained tranny fluid and refilled. I remembered something on here about not removing hex bolt from the top, I tried to tell them but when I looked he had already done it. Now reverse doesn't work. I don't know what to do now. And neither does the mechanic apparently. I hope one of the techs is out there and can help.
Old Jul 30, 2011 | 03:04 PM
Gold_04_X-Type's Avatar
Sorry to be the bearer of bad news, but I belive once that has been done, the transmission must be disassembled so the reverse band can be adjusted back to the correct position.
Old Jul 30, 2011 | 03:16 PM
queenmb's Avatar
Thanks Gold. I was afraid of that. :-(
Old Jul 30, 2011 | 07:29 PM
Elmoski's Avatar
get them to do it free, they mucked it up, they should fix their error
Old Aug 2, 2011 | 08:05 AM
Chopper's Avatar
well, yes, it is messed up. The reverse band brake bolt was removed.
The trans shop I talked with has a tool that can reset this most of the time. It is a well known mistake and the really good trans shops can get you straightened out for a minimal charge. The rest will tell you you need a complete overhaul.
Old Aug 2, 2011 | 09:55 AM
The Chris X's Avatar
^yep.
Get the car to a tranny specialist, with this mechanic footing the bill of course.
Johnken
Oct 2, 2015 10:12 AM
Poet
Oct 2, 2015 09:00 AM
millertic
Sep 30, 2015 08:11 PM
jjmiah217
Sep 28, 2015 09:09 AM
