Noise from tachometer.
Old Jul 27, 2013 | 07:46 PM
shotime92's Avatar
Default Noise from tachometer.
Right around 1,500 rpms I'm hearing a noise from the tach. What could it be? Wondering if anyone else had this problem.
Old Jul 30, 2013 | 09:07 AM
shotime92's Avatar
Noone?
Old Jul 30, 2013 | 10:22 AM
JaguarXKR's Avatar
Mine makes a grinding noise as the car shifts to a higher gear and the rpms go down. I'm not sure if this is what your talking about.
Old Jul 30, 2013 | 08:02 PM
shotime92's Avatar
Yes it does. And it's coming from the tach on yours also?
Old Jul 30, 2013 | 08:34 PM
Gold_04_X-Type's Avatar
My tach grinds on decel under 1k RPMs. Has been that way for the three years I've owned mine.
Old Jul 30, 2013 | 09:44 PM
JaguarXKR's Avatar
Yes it does. Mine has done it for years. Maybe the gears behind the dashboard are not lubed properly. My XJ Vanden Plas with 9k miles on it does the same thing, I have started to notice. Not sure if i will ever do anything about it. Don't listen for it anymore but I know it makes noise, when I have no music on, which is almost never.
Sorry I can't tell you any fixes or anything, but yes mine does the same thing.
All the best,
Mike
Old Jul 30, 2013 | 10:10 PM
shotime92's Avatar
I'm going to pull the cluster out and take it apart and see if I can find and or lube anything. Will give an update and a how to if I find anything.
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
ChrisJay
Sep 27, 2015 09:08 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
