Not very cold A/C
I've recently (today) developed a problem with my A/C. It gets cool, but not cold. I figured that it was probably low on refrigerant, but checked the pressures in the system and they appear to be pretty normal. 40ish PSI on the low side and 230-240 PSI on the high side. I can't get at my workshop manual (haven't tried to since I put on Windows 7). It exhibited all the signs of low refrig.. would warm up at a stop light, etc. Any ideas as to what's going on? Friday the 13th strikes again!
Yes I am. No problems with air flow. I'm fairly convinced it's low freon, but the pressure readings make me leery of just dumping freon into the system. The system worked ok on Thursday, but not Friday....roughly the same temperature both days....
Is the return line (LP side) in the AC cold? If it is then the refrigerant side of the system is working and the problem is probably getting cold air out of the system. If the door actuator has failed/malfunctioned you can still get good airflow and no cold air.
Also set the temperature to the highest and lowest settings for a while to move the actuators.
The line was cool, not cold, so I added about 3 oz. of freon and the system is working much better. The pressure is still in line with what it should be so I'm going to assume that it was just low freon and call it a day!
Check the clutch plate assembly on the compressor, (Ran by serpentine belt) on bottom of passenger side. Mine just failed and is now making loud grinding sound and after inspection and research on this site, I have found that the part failed and is literally falling apart.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
Sep 26, 2015 07:04 PM
