Oil change
Old Aug 10, 2012 | 02:01 PM
fat sam's Avatar
Default Oil change
changing oil and filter tomorrow, does anyone have any pics of filter location, so i know what i am up against? i here it is in an awkward place.
Mark.
Old Aug 10, 2012 | 03:00 PM
Thermo's Avatar
Veteran: Navy
fat sam, 2 big things to keep in mind when doing an oil change on an X-Type. The first one that you are going to run across (or you may not, I'll explain) is there is a scoop that is mounted to the underside of the motor that runs right in front of the drain plug. You need to remove the scoop before you drain the oil else you are going to have a big mess on your hands. The trick is that this scoop is the lowest point on the car and it is made of plastic. As you can guess, it is really easy to rip right off of the car and I would say 99% of X-types don't have it installed.
As for the filter, it isn't hard to access, just not out in the open. If you open the hood and you are looking into the engine bay with your knees where the front license plate should be. If you drop your left hand down behind the radiator, you will see the filter down there. To access the filter, you will need to lay on the ground and look up at the bottom of the car. Right under where you saw the filter, you will see a 12cm x 12cm opening in the plastic shield under the radiator. If you look up in that opening, you will see the oil filter there. Stick your hand up there and spin off the filter. It is sitting at about a 45 degree angle. So, be ready for some oil to come out. I have big hands and I have no problem getting the filter out.
Old Aug 11, 2012 | 02:00 PM
fat sam's Avatar
Thanks Thermo, was out there at 6.30 this morning. All went very straight forward, no scoop fitted to mine and all done in 30 mins.
Thanks again for the reply. Mark.
aholbro1
Dec 29, 2024 06:46 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
ZJag
26
Sep 5, 2016 03:33 PM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
