Oil leak help to diagnose
Old Dec 26, 2021 | 10:28 AM
Jason Holman's Avatar
Default Oil leak help to diagnose
Hi guys
i have an oil leak and took it to the local lube shop to have them look at it quick to see if it was the plug or filter but they said both were dry.
here are some pictures..
can anyone give me some detailed info on what they see and how much to fix or easy it is to diy.
thanks for any help!
Old Dec 26, 2021 | 11:48 AM
NBCat's Avatar
What is the MY and how many kilometres are on the vehicle?
Appears to be the cam cover gasket(s) and the spark plug boss seals need to be replaced. Requires removal of the upper inlet manifold to access Bank 1 if that's also in a similar condition. Not a difficult task depending on your skill level and available tools.
Old Dec 26, 2021 | 09:11 PM
Thermo's Avatar
Veteran: Navy
Like NBCat said, looks like a valve cover leak. The part that I am a bit confused about is how the oil got on top of the air intake harmonizer (that long slender tube coming off the intake). All I can figure out is oil is coming off of the PCV valve and being wicked over to that spot via the insulation on the hood/bonnet. SO, replace both valve cover gaskets and if needed, look at the plug wells and see if you need new seals for those too.
Old Dec 28, 2021 | 05:35 PM
Thanks for the reply! NBCat & Thermo
NBCat, when you say MY, what do you mean? Milage is 169000kms, and it’s a 2004
so if I were to order the parts before I pull it all apart before having to do it twice, what would you suggest I order exactly?
thanks again guys
QUOTE=NBCat;2478956]What is the MY and how many kilometres are on the vehicle?
Appears to be the cam cover gasket(s) and the spark plug boss seals need to be replaced. Requires removal of the upper inlet manifold to access Bank 1 if that's also in a similar condition. Not a difficult task depending on your skill level and available tools.[/QUOTE]
Old Dec 28, 2021 | 07:04 PM
Dell Gailey's Avatar
MY = model year
Check this as well just to be safe (sometimes mistaken as oil leak) =
https://www.jaguarforums.com/forum/x...engine-217754/
sunchip
Aug 28, 2023 09:21 PM
VancouverXJ6
May 20, 2023 07:02 AM
67Camaro
Nov 30, 2021 11:01 AM
scubayachts
Nov 8, 2008 05:06 PM
