Oil light and engine code
Old May 27, 2017 | 07:15 AM
02nvjag's Avatar
Cool Oil light and engine code
Hello everyone new to owning a Jaguar and a few issues having one hell of a time figuring out.... I just bought a 2002 X-Type. car drives great however after getting the oil serviced two weeks ago while driving it today the oil light came on then off while breaking then went away when I started to accelerate. Also the engine light stays on did a code test and reset the system the engine light went away for three days then back however there is a code P0430.... did some checking and the list goes for days on what the issue may be help thanks
Old May 27, 2017 | 09:18 AM
Welcome to the forum 02nvjag,
As you've posted a separate Intro, I've moved your question from New Member Area - Intro a MUST to X-Type forum. Members here with the same model will be able to help.
Old May 27, 2017 | 09:29 AM
Alfadude's Avatar
The P0430 code is for the HO2 sensor in Bank 2. There are two of them, the upstream and downstream. You might want to replace both of them and go from there.
The oil light, like someone else mentioned, check the level. It might be near the bottom of the correct fill level. Once you verify that is correct keep an eye on it to see if it drops at all.
ecamiel
Nov 14, 2019 07:28 PM
enigma
Jan 2, 2017 11:40 AM
geewilicurs
Oct 11, 2016 12:00 PM
Rogerdavis
Oct 4, 2016 11:39 AM
Nov 29, 2005 10:55 PM
