Oily Air system
Old Mar 15, 2021 | 06:59 AM
Onielle's Avatar
Default Oily Air system
My Xtype 2003 model is beginning to pick up oil in the airflow meter chamber.
indeed, my engine oil is draining just as much.
I can even smell auto lubricant through the air condition fans.
Any advice?
Old Mar 15, 2021 | 06:27 PM
Thermo's Avatar
Veteran: Navy
Onielle, sounds like your PCV valve is failing and needs to be replaced. Take note of the color PCV valve that you have. There are slight differences and you need to get the same color. It should be either purple or gray as I recall. See what you have after replacing the PCV valve.
Old Mar 15, 2021 | 08:46 PM
Dell Gailey's Avatar
VITO76
May 18, 2017 08:36 AM
NigelM
Apr 7, 2014 10:07 AM
Robert Scott Neilly
Mar 15, 2014 08:26 AM
skanoski
Sep 14, 2010 11:35 AM
Hong
Jul 13, 2008 11:43 PM
