Outside door handle increasingly inoperative
Old Aug 17, 2011 | 11:09 AM
steve12955's Avatar
Default Outside door handle increasingly inoperative
Hello,
Search didn't turn-up the information needed. My '03 X-Type passenger door handle-to-latch link rod seems to be worn or out of adjustment. I've moved the door post striker a little and it works for awhile but I suspect the rod will have to be replaced. Pushing lightly against the door frame while lifting the outer handle, you can hear/feel the lock release and the door opens but it's a pain. Part number for the updated rod is C2C28890 and it isn't expensive.
AllData says that to replace the rod the outer door handle must be removed and to do that, the door glass and window motor are supposed to be removed, too. That seems excessive to me. Has anyone ever replaced the handle-to-latch link rod without removing the window mechanisms?
I recall reading here that someone was able to bend the rod slightly in place to bring it back to spec but can't seem to locate the post. Any assistance is appreciated.
Thanks,
Steve
Old Aug 17, 2011 | 11:16 AM
Steve, I'm sure this has been covered in the X type FAQ quick link thread.....there's also a "how to" for removing /replacing the door cards
https://www.jaguarforums.com/m_4382/tm.htm
https://www.jaguarforums.com/forum/x...oor-faq-48827/
Old Aug 17, 2011 | 11:21 AM
steve12955's Avatar
Jim,
Thanks. I found the correct link just as your reply came through.
Steve
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
hoodun
Sep 7, 2015 07:02 PM
