P0420
Old May 9, 2012 | 08:54 PM
leaperjag's Avatar
Default P0420
I just fill my car up at the gas station, when I started it and heard a pop noise. The check engine light started flashing, the car was making a loud noise and a little bit of smoke came out the back. The only code I got was P0420. I have checked the plugs and coils( there a couple weeks old) they looked good, Theres no oil on them. My O2 sensors are a few months old.
Does this sound like I need a new catalytic converter?
Old May 10, 2012 | 12:40 AM
disguay's Avatar
I got a set of weird codes at the gas station. Try this just for S***s and giggles. It worked for me and it's worth a shot.
It's complicated so listen up...
Undo the gas cap
Let the tank "breathe" for 5 seconds"
Tighten the cap to 3 clicks
delete the code and see if it comes back or not
I know... it's complicated
Old May 10, 2012 | 01:10 AM
torresxk8's Avatar
p0420 is a cat. code 9 times out of 10 its the cat and aftermarket cats suck. if you had a miss or a front o2 that was bad for a time you may have burned up the cat over time. it only takes a 15-20% clog to set the light on a obd2 car (96-now). if you use a aftermarket cat reprogram the pcm with any new updates that are out even new car have pcm updates.
elardizabal
Oct 27, 2018 06:44 PM
hhv00586
Aug 21, 2015 10:13 AM
new2me
Jul 26, 2015 03:45 PM
abdothegreat
Feb 8, 2014 07:43 AM
stshots
Feb 15, 2011 09:20 PM
