P1646 code issue
Old Jun 29, 2013 | 02:03 PM
M9G's Avatar
M9G
Default P1646 code issue
Hi
So I got my 2002 2.5 x-type today which has engine light on, I plugged lapper in and it has a P1646 code, the previous owner said it was to do with bank one sensor 1 which he said has been replaced but light still comes on.
Is it possible that its another oxygen sensor at fault?
Can someone tell me where each oxygen sensor is on the car so I can check out to make sure bank1 sensor 1 has been changed.
I did read somewhere else that it might be a fuel pump relay, is this right?
Thanks for any help you can give
Old Jun 29, 2013 | 03:48 PM
Bud Tender's Avatar
Here is a thread from someone that says the problem is now fixed.
https://www.jaguarforums.com/forum/x...6-fixed-64133/
Old Jun 29, 2013 | 04:58 PM
M9G's Avatar
M9G
ok thanks, ah yes came across that one earlier, only thing is he said he got all 4 replaced and that cured it.
I'll stick it in a local garage to determine exactly which one it is as I cant afford to throw money at it and replace all four
Old Jun 30, 2013 | 04:04 PM
M9G's Avatar
M9G
I see in JTIS21 P1646 says "LINEAR 02 SENSOR CONTROL CHIP (BANK 1)
Would I be right in thinking this means pre-cat sensor and not the one on the cat?
Also is bank 1 next to the bulkhead? and bank 2 is radiator side?
Old Jun 30, 2013 | 05:33 PM
Here's the Jaguar X-Type 2002MY DTC Summary extract for P1646:
And the HO2S locations:
(click on the images to enlarge them)
Old Jul 1, 2013 | 01:29 AM
M9G's Avatar
M9G
Thanks, thats really useful info
Which set is bank 1? 1&4 or 3&2
I dont want to assume sensor 1 is bank 1 although it would make sense but then I would have thought sensor 3 would have been sensor 2 being bank 2 but obviously its not.
Old Jul 1, 2013 | 02:28 AM
Doesn't cylinder numbering just cry out for a consistent system!
( click on the images to enlarge it )
The V8 is even worse with three different - current, alternate and historical cylinder numbering.
Old Jul 1, 2013 | 03:41 AM
M9G's Avatar
M9G
lovely thanks, so bank 1 bulkhead cheers
Old Jul 1, 2013 | 04:17 AM
M9G's Avatar
M9G
hahaha
previous owner said he had bank1 sensor changed and it didnt cure the fault, just had a look and whoever replaced it replaced bank2 sensor, OE sensor ordered and will be replaced tomorrow :-)
Thanks for help guys :-)
Old Jul 2, 2013 | 09:48 AM
M9G's Avatar
M9G
Replaced and Management light is now off so all good :-)
Thanks guys for your help and advice
philwarner
Oct 4, 2024 01:37 PM
Bcrary3
Sep 12, 2021 05:41 AM
OkieTim
Sep 8, 2015 04:48 PM
Bowman
Sep 3, 2015 03:17 PM
OkieTim
Sep 2, 2015 12:48 PM
