Poor idle, no performance
Old Jan 3, 2007 | 02:42 PM
racerx82's Avatar
Default RE: Poor idle, no performance
I've been hearing alot of this re-flashing the ECU business, but never hear back if it worked...
My question to you is, when was the last time you had a tune-up, plugs, coils, oil, air and fuel filter changed??
Being it's a 01, i'm sure you have some milage on it...and getting the injectors cleaned would be a great benifit as well....of course, if you're not a DIY kind of person, everything i just mentioned will probably cost around 500-600+
If getting the ECU re-flashed will cure your problems than you just saved some big bucks...
Good luck
Old Jan 3, 2007 | 06:08 PM
michaelnv's Avatar
This site might answer some questions
http://www.jaguarforum.co.uk/viewtop...sc&start=0
Scroll down to BuckMR2 post.
I've read resetting the computercould actually reset at a worse setting than what it is now and being the Jag learns your driving habits it will probably go back to the original settings.
Might be worth a try through.
Let us know if you do this and the results.
Old Jan 3, 2007 | 06:49 PM
Humy's Avatar
injectors could be the problem - most likely your cylinders are misfiring, due to a ECU issue
Old Jan 3, 2007 | 10:33 PM
racerx82's Avatar
oh man, i was hoping you would list everthing in the book....
Old Jan 4, 2007 | 07:39 AM
racerx82's Avatar
Sweeeet....can't wait.....! Thanks
Old Jan 4, 2007 | 10:18 PM
aquill1's Avatar
Hey baz, I'm in Auburn Hills and I'll be going to the show next week- well actually probably next Friday once its opened to the public. What are you going to be doing there?
Old Jan 5, 2007 | 06:57 PM
aquill1's Avatar
Yeah I don't know when I'm gonna be going but I usually go like the last Friday its open. There isn't anything spectacular going on at that point and time but they also aren't jam packed either.
Old Jan 8, 2007 | 10:04 PM
Oldengineer's Avatar
You didn't by any chance get a tank of gas with water in it?? That'll cause the symptoms you've got as well.
Regards:
Oldengineer
Old Jan 8, 2007 | 10:14 PM
racerx82's Avatar
I had the same problem last summer.....started the car, moved it 3 inches, turned it off and washed it.
1 hour later it just wouldn't start.....turned out i had air in fuel system...had to flor the pedal a few time and she spitted, choked and stumbled and i let her warm up and she ran like nothing happened....strange, hasn't happen since..
Old Feb 6, 2007 | 02:26 PM
OMG Chris, you're so lucky.
I had that a few years ago now in the Peugeot I had at the time which was a diesel. I filled up with a full tank which turned out to be about 50% fuel and 50% water..........what a nightmare.
Took a total draining of the system to cure it and the cost the local garage a pretty penny I can tell you.
I had white smoke comming out the exhaust and eventually in whatever gear I was in, the speed just fell away until I had to pull over.
Not an experience I'd like to repeat I can tell you
Glad you got it sorted in the end mate..........what a relief huh?
Jim C
JCam
Oct 23, 2016 08:27 PM
philwarner
Jan 31, 2016 09:36 AM
1100me
Oct 1, 2015 11:49 PM
reb1999
Sep 26, 2015 08:41 AM
