Positive battery cable
Old Sep 19, 2016 | 04:10 PM
Mrclean1's Avatar
Default Positive battery cable
Ok, so I'm very new to all this, hope it goes through. I bought a 2003 x type. The battery light came on. Read as many Post's adi could and found out that my cables could be bad. Once i looked at cables the Post's were terribly corroded, I cleaned them, still have an occasional light. So I was going to change the cables, but before I did, i noticed a small cable that's connected to the positive wire that goes to fuse box that's not pluged in anywhere. Should it be? If so where? Thanks
Old Sep 19, 2016 | 09:07 PM
Firstly welcome to the Forum.
I have NO answer.
I suggest a quickie repost in the X Type tech section, where the guru's will have that answer.
When time permits please do an Intro in the New Members Area.
Old Sep 20, 2016 | 12:43 AM
Originally Posted by Mrclean1
..... noticed a small cable that's connected to the positive wire that goes to fuse box that's not pluged in anywhere. Should it be? If so where?
Welcome to the forum Mrclean1,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Sep 20, 2016 | 07:59 AM
avern1's Avatar
A picture would help greatly with this one. Is the wire connected to the positive post? Or is it connected to the fuse box? Or is it connected at one end to the positive post and the other end to the fuse box?
Old Sep 20, 2016 | 09:13 AM
Mrclean1's Avatar
Default Photo
Thanks Avern1 for replying. Here is a photo of what I'm looking at. The cable my finger are under is the positive cable that runs from fuse box to battery. The plug on the smaller wire was just laying under fuse box. Moved it for pic. .any ideas?
Old Sep 20, 2016 | 09:16 AM
Mrclean1's Avatar
sorry forgot to upload.
Old Sep 20, 2016 | 09:25 AM
Alfadude's Avatar
That is just something that was used when the car was transported when new. You can ignore it. It has no use now. I believe there is a spot by the battery you can plug it into if memory serves.
Old Sep 20, 2016 | 09:57 AM
Mrclean1's Avatar
Thanks for the info Alfadude,
I also noticed that the positive cable going to the solenoid is also connected to the cable going to the alternator with one cable end. In other words, to cange the cable, it looks as the i have to unhook it from alternator. Is this a jag thing, or did someone make the cable this way.?
Old Sep 20, 2016 | 10:53 AM
Bud Tender's Avatar
While you are looking at battery cables be sure to check both ends of the ground cable, they are known to corrode where it connects at the frame end.
Old Sep 20, 2016 | 11:11 AM
Mrclean1's Avatar
Thanks Bud, I'm gonna go ahead and change them both, but i did notice that on the solenoid the cable was loose, in other i could move it up & down, I'm thinking this might have caused a lot of my problems. It wasn't making good connection. Although it has always started.
Thermo
Sep 11, 2016 07:44 PM
dspguitar
Sep 7, 2016 07:39 PM
MJTgroup
Sep 5, 2016 01:09 PM
lzarc1
Aug 29, 2016 06:41 PM
Mgallard
Aug 23, 2016 02:25 PM
