Power steering fluid?
Old Aug 29, 2008 | 06:58 AM
queenmb's Avatar
Default Power steering fluid?
Does it matter what kind of power steering fluid is used in the X type? Do I have to get it from the dealer? Or can I just use what they have at AutoZone?
Old Aug 29, 2008 | 12:32 PM
Dennis's Avatar
ud
Default RE: Power steering fluid?
I think it does matter..I went to the dealer for mine, but you can call them and see if there is something you can get from an auto parts store that will work..
Old Aug 29, 2008 | 01:04 PM
hankycbr's Avatar
I used just regular power steering fluid from Autozone and have no problems. Just make sure you put in the right coolant reddish in color not the green one!
Old Aug 29, 2008 | 10:53 PM
Dennis's Avatar
ud
I'm pretty sure, the run of the mill powersteering fluid at AZ is not compatible..I hope it is for your sake..it may not show problems right now..
and as far as the coolant ..you should use only Jaguar anti-freeze..it is different in the chemicals used, because of the pump design and alloys of the coolant system...So Dex-cool may work for a little while..But why chance it?
Old Aug 30, 2008 | 08:36 AM
queenmb's Avatar
Thanks guys. Since Ill have to take my Jag to the dealer to see about my recent rear end accident anyway, Ill just pick some up then.I dont think I need to add coolant yet, but will definitely make note of this info for future reference.
Old Aug 30, 2008 | 01:28 PM
Dennis's Avatar
ud
Just make sure Queen, that you mix it 50/50 with distilled water ONLY!
Old Sep 2, 2008 | 11:41 AM
BuckMR2's Avatar
You need Dexron IIE according to my owners manual (different to coolant hankcbr)
Old Sep 2, 2008 | 10:03 PM
hankycbr's Avatar
BuckMR2,
you do have a point. next time I am running low on coolant, I will definitely buy some from the Jag Dealer. thanks for pointing it out.
sogood
Sep 15, 2015 07:35 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
