Problem with wastegate/vacuum
Old 12-18-2012, 01:39 PM
Big Al's Avatar
Question Problem with wastegate/vacuum
Hi, am hoping someone can help me with this one, I've taken it to a friends garage a couple of times and he has suggested perhaps the next step is replacing the turbo (would clearly prefer to avoid this)
I have a 2004 2.0d sport x type, it runs perfectly fine then all of a sudden for no reason has no power whatsoever.
Fortunately I was around the corner from friends garage when it happened once so took it to him and the wastegate was stuck open and when I take the hose off there is no vacuum.
As soon as I turn the engine off/on again the wastegate functions properly and there is a vacuum.
I can take the hose off/on again and every time the wastegate is opening and closing.
I don't know what is causing the loss of vacuum and clearly want to avoid replacing the turbo. Can a wastegate itself be changed. I have no mechanical knowledge whatsoever but am helped by google, research shows it could be solenoid? Actuator (I think) hoses?
Any help/guidance would be appreciated.
Al
Clamdigger
09-12-2015 03:43 PM
mcdutch
09-04-2015 03:38 AM
obwoodie
09-03-2015 07:45 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: Problem with wastegate/vacuum
