pulley or tensioner grinding noise
Hi all,
I need to pick someone’s brains here… I have a Jaguar 2.1 Petrol manual. When she is cold everything is fine, however, we she has been running and warmed up I can hear what sounds to be a pulley or tensioner grinding noise. Do Jaguar x Types have any known tensioner problems?
No belts are slipping and the clutch seems ok too, it only happens when I move away from stationery at around 1000 -1200 rpms
Thanks in advance,
BTY is there an app for this website as I now have an all new IPhone
Thanks in advance,
Hi Cyberice,
I don't know about the ipod app and I hope this thread/link helps?
https://www.jaguarforums.com/forum/x...esolved-69195/
Regards Stu
Regards Stu
Both the serpentine and water pump tensioners and the idler pulley bearings were worn out on my 02 X type and made tons of noise.
Worst one was the small water pump tensioner it was really bad.
Simple to diagnose, remove belt and give them a spin, the ones that aren't quiet and have a little resistance to them are worn out.
Good news is that they are pretty cheap and easy to swap out, it cost me less than $150 for all of them and had them changed out in about 2 hours.
Let us know how it works out.
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
