random failure to start
Old Aug 8, 2011 | 10:08 PM
dwightf's Avatar
Default random failure to start
When I turn the key to the starting position, the engine does not sart, the dashboard lights do not come on, the starter motor does not turn over (no clicking), the console red security light does not light up. This seems two happen more often after just opening and closing the trunk. Once I let the car sit for 12 hours after it failed to start, then it started without doing anything. I had a new battery and new grounding cable installed. These did not solve the problem. This has happened 4 times in the last 6 weeks. Dealer could not diagnose the problem because the car started every time at the dealer.
Old Aug 9, 2011 | 03:06 AM
baffourg's Avatar
Check the battery terminals. They may not be tightened correctly. I will advice u to remove the battery terminal, clean them and put them back. Am sure u can DIY without going to an expert. Good luck
Old Aug 10, 2011 | 09:01 AM
dwightf's Avatar
Thanks. I had a new battery put in last month, as well as a new grounding cable. Posts are clean, clamps are tight. I double checked. Car failed to start again since my first post. I noticed that the security light on the console did not flash when the car was locked. I think the problem is related to a security system failure.
Old Aug 10, 2011 | 02:58 PM
sidewalkman's Avatar
since it's no lights on the dash whatsoever, I think it might be a main fude issue, pull it and clean it, check the relays etc, anything electrical.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
OkieTim
Sep 8, 2015 04:48 PM
34by151
Sep 6, 2015 05:14 PM
