Rattles in a 2004 X-Type 3.0
Old Nov 20, 2010 | 08:09 AM
GaryMO's Avatar
Default Rattles in a 2004 X-Type 3.0
Getting an annoying rattle on the passenger side at highway speeds, but having a tough time locating the source. Where are the common rattle points on this car? Thanks.
Old Nov 20, 2010 | 09:10 AM
TheSeeker's Avatar
Make sure there's nothing in the glove box that's rattling. Also check if the glove box door itself isn't the cause....just reach over while you hear the rattle and push it closed tighter.
Old Nov 20, 2010 | 12:13 PM
Thermo's Avatar
Veteran: Navy
Gary, check the trim on the passenger doors to make sure that it isn't coming loose and is tapping the door due to the wind. Next, up near the windshield, there is a small trim piece that runs from the windshield to the rear window. The front of this can come undone and it will flap around due to wind and make an annoying noise.
If it isn't those two things, if you could explain the noise a little better (ie, like metal on metal, tapping a pencil on a sheet of plastic, etc), it might help us narrow down the noise a bit more.
Old Nov 22, 2010 | 07:41 PM
GaryMO's Avatar
Thanks Chris. Looks like it may have been the right edge of the trim piece that runs the span of the windshield. Didn't even think to check that out. I pushed it down tight, but if it comes up again I'll just apply some light epoxy.
Thang Nguyen
Oct 12, 2015 01:25 AM
jhn
Sep 21, 2015 09:43 PM
CJagB
Sep 19, 2015 05:00 PM
the whittys
Sep 15, 2015 01:47 AM
DatDude
Sep 8, 2015 11:36 PM
