Re programming Key Fobs
Old Dec 13, 2009 | 01:38 PM
2000SType40's Avatar
Originally Posted by Gessie
I've been doing more research and it seems that my car may need to be done using a IDS tool, I hope not since my Jaguar dealer may want around $200 to do it and I can't see paying that much. So I'll keep looking for another answer.
Any progress? (I have the same problem)
Old Jan 10, 2010 | 12:58 PM
gbrutschea's Avatar
this works but dont be afrid to try several times until successful. fobs seem to act like they are dead but the batteries last a long time
Old Oct 1, 2010 | 03:43 PM
I <3 X-Type's Avatar
HELLO EVERYONE!!!! I THINK THERE IS A MISTAKE IN THE WRITE UP!!!!!!
I just bought a FOB off ebay the other day and just tried it as it is stated in the directions. The problem im having is it didnt make any noise and was not working!!!! So in my experience with other programming i turned the to the III mark instead of the II!!!!!!! So turn the key to the II position then turn it to the III position four times you will here the beeps. Aftyer the beeps press lock or unlock on both or all key fobs one right after another. THAT WORKED!!!!! I to II doesnt. II to III does!!!!! Hope this helps!!!!!!
Old Oct 3, 2010 | 07:56 PM
rjs852's Avatar
I have tried everthing and still can't program remote.I hear the chime and within 10 secs press any button but nothing works. any suggestions?
Old Oct 3, 2010 | 08:56 PM
exrub's Avatar
If you hear the chime but nothing works when you press the button, you might have a dead remote.
Old Oct 3, 2010 | 08:59 PM
motorcarman's Avatar
Here is the TSB info from Jaguar that you need to read.
bob gauff
File Type: pdf
File Type: pdf
Old Jul 3, 2011 | 05:00 PM
snowman3's Avatar
whats the solution if i only have 1 fob 1 key and the fob died? if i bought another fob is it reprogrammable without dealership service?
Old Jul 3, 2011 | 05:34 PM
  #28
BuckMR2's Avatar
As long as you have a key that can turn the ign on you can program ANY suitable fob for your region.The X Type fob can also be programmed to use with an XJ (X350) and vica versa as I reprogrammed my spare X Type ones for my XJ.Its the region frequency that is important so IK ones are no good for US market as the frequencies are different.
Old Jul 3, 2011 | 05:44 PM
jaglover922's Avatar
Are you taking about the remote portion of the key, or the physical metal key. The remote can be programed without the dealership. If you have 3 or more keys you can program the keys without the dealership. If you are only programming 2 keys, like you only have 2 keys and that's it. That programming must be done at the dealership.
Old Jul 3, 2011 | 05:59 PM
  #30
BuckMR2's Avatar
The guy said "the FOB died"
FOB = REMOTE PORTION OF THE KEY
The guys FOB died not his key!
Old Jul 3, 2011 | 06:07 PM
  #31
Thanks. I see that now. My experience at dealing with certain people is that they don't know what they are talking about, like a lot of people on this forum. I was just explaining a way to help him/her. Thanks for the bold writing buddy.
Old Jul 18, 2011 | 04:39 PM
  #32
shula's Avatar
My spare key fob stopped working. I can still use the key to unlock/lock and start my Jaguar X type, 2003. When I push the buttons to remote lock/unlock/trunk/lights, nothing happens. I assumed it was the battery, so replaced it, still nothing. I took the fob to Auto zone and tested it, and it is transmitting. Is there a fuse or something that would not allow it to transmit?
Old Jul 19, 2011 | 01:13 AM
  #33
BuckMR2's Avatar
If you took too long replacing the battery or the old battery was drained the fob needs recoding
Your old battery might have depleted so the fob wouldnt work (usually you have to get nearer and nearer to the car as it depletes) and the new one wont work until its recoded
Simply to recode in seconds follow the instruction on the forum
If it has been recoded and still doesnt work spray some WD40 on the ignotion switch flap which should move when you put your key in the ignition, it often sticks causing fob probs
Old Jul 19, 2011 | 01:32 PM
  #34
ufoz8mycow's Avatar
Here's my question...
The first time my key "lost" its code and I had to reprogram it was last month. Never happened before then in 3 years of owning my car. Since then, I have to reprogram the key at least once or twice a week... What gives? The battery in my fob is good, also replaced about a month ago.
Old Jul 19, 2011 | 01:56 PM
  #35
BuckMR2's Avatar
There was a fault with some fobs something to the metal shield inside the fob.Only affected some VIN ranges I think if I remember there was a TSB.Try checking through the TSBs listed on the forum
Old Aug 10, 2011 | 11:34 AM
  #36
mohrd's Avatar
Confirmed. Replaced a battery in a remote that wasn't working. It can start the car but no remote buttons were working. Tried programming it with I to II but no GEM chime. Tried II to III and the GEM chime happened and the "good" remote would program. Sadly the other didn't. Looks like a dead remote for me. Off to do some shopping I guess.
Old Aug 10, 2011 | 12:06 PM
  #37
Kota62's Avatar
Just something to consider, my wife had several old Ford (07 Mustang) remotes lying around the house...
Took two and successfully programmed them
Gary
Old Aug 19, 2011 | 10:06 PM
  #38
mohrd's Avatar
Not to beat the dead horse but, $23 later from Remotez4Less, four turns to III position and the magic GEM chime and we are back in business.
Old Aug 22, 2011 | 10:12 PM
  #39
snowman3's Avatar
Same here I went and bought a new remote off Ebay and followed the instructions posted on here. It worked.
Old Sep 4, 2012 | 08:21 PM
  #40
Sparkchaser36's Avatar
Smile Happy!
Ordered a remote from Remotez4less for my wife's 2002 X Type. Used the instructions at the start of the thread and HOLY CRAP!!!! It actually worked!
