Ready to do ATF Change - Question
Old Jan 10, 2011 | 05:13 PM
Rob R's Avatar
Default Ready to do ATF Change - Question
After reading as much as I can I'm going to tackle this over the weekend.
Here's my question: Is it ok to reuse the transmission fluid level plug and sealing washer? JTIS says to install a new one. Curious to know if those that have done this replaced or reused?
Thanks in advance!
Rob
Old Jan 10, 2011 | 05:15 PM
sidewalkman's Avatar
The popular theory is that the washer is a crush washer so no, get a new one.....I re-used mine and haven't had a leak.
Old Jan 17, 2011 | 05:31 AM
TonyX's Avatar
I've changed my trans flud twice now reusing all the washer/plugs. No leaks.
BTW, I'm using the Castrol Import ATF for the last 25K miles. No issues.
Used Merkon V for the prior 20K miles. No issues.
Old Jan 18, 2011 | 11:33 PM
RobGardnerBlack's Avatar
Rob, three points make a trend - I too reused the original washers and plugs with zero leakage.
I am also using the Castrol Import ATF with zero issues.
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
D.K
Dec 10, 2023 02:05 AM
XJsc-guy
Nov 23, 2015 01:56 PM
TC Johnson
Sep 2, 2015 09:30 AM
