rear doors won't unlock
Old Aug 3, 2016 | 03:44 PM
Wahooesprit's Avatar
Default rear doors won't unlock
Hello
The doors will lock from the inside driver side or the key fob. The fob will only unlock the driver door--can manually open the the lock from inside for the rear doors and front passenger....car is a 2005....am I missing anything?
Side note--my 2002 was hit in front driver side--totalled as repair was $5500 so took the $4400 settlement, bought the car back from insurance company for $287--found this 2005 for $1500 on craiglist with bad transfer case and bad transmission--swapped out case from wrecked car and put on a new side pan gasket for transmission--total cost $20 for gasket, 12 hours in my garage..
the 2002 sits in driveway as my donor (think the Island haha)
David
2005 x type
Old Aug 3, 2016 | 07:07 PM
Thermo's Avatar
Veteran: Navy
Wahoo, if only your driver's door is unlocking using the keyfob, then odds are the switch for the door lock position is toast and the computer is not seeing the driver's door unlock and therefore, when you press the unlock button 2 times, it tries to unlock the driver's door twice (thinking it didn't unlock it the first time).
Old Sep 13, 2016 | 02:25 PM
Default Rear door locks
The problem fixed itself when I unhooked the battery last week for 2-3 hours to replace the headliner--weird but not complaining......
Tomica
Other Areas
Sep 20, 2017 01:50 AM
razorboy
Mar 29, 2016 01:08 PM
Jul 28, 2014 07:18 PM
Interior
Jan 24, 2007 04:50 PM
Exterior
Mar 30, 2006 03:41 PM
