Rear driveshaft question.
Old May 28, 2022 | 06:36 PM
03 Sandy's Avatar
Default Rear driveshaft question.
If rear driveshaft is removed for carrier bearing replacement can the car still be driven in two wheel drive until the driveshaft is replaced ?
Old May 28, 2022 | 06:45 PM
03 Sandy's Avatar
Default Rear drive shaft question. . .
Sorry didn't mention the car is a 2003 Jaguar X Type 3.0 AWD.
Old May 28, 2022 | 07:16 PM
Thermo's Avatar
Veteran: Navy
Sandy, will the car move. Sure will. Is this something that I would recommend doing for a long drive. now way in hell. I say this for a number of reasons. The big thing being that your transfer case is not meant to take all the power to a single wheel (which is what is going to happen in this case. The case is going to flex and most likely result in it failing. Also, there is not much fluid in the cases and you are going to be stressing the viscous coupling to force all the power through to the front end. This is most likely going to cause that to run really hot and lead to damage. So, will it work. Yep, but I cannot say I would do it for long trips of say more than 1/4 mile (0.5 KM). Even then, it would be under very light throttle. You also risk causing damage to the CV joints and parts like that as they are only meant to take up to 50% of the possible engine power and you could potentially take them up to 100%, which may exceed what they can handle.
quartetchiang
Jan 11, 2021 10:21 AM
Razorback31
Sep 29, 2014 05:44 AM
Harleychris1969
Jan 1, 2014 08:12 PM
TN8Shooter
Jun 5, 2012 12:18 PM
JagScott
Nov 28, 2010 06:51 PM
