Rear Parking Sensors
Old Sep 24, 2012 | 09:26 AM
Bandit1985's Avatar
Default Rear Parking Sensors
Hi all, Noticed last night when reversing instead of the normal change of beep when reversing closer to objects, I had one long continuous beep even though there was nothing behind me?
Any ideas?
Old Sep 24, 2012 | 02:23 PM
Thermo's Avatar
Veteran: Navy
Bandit, that long tone is the "error" signal. One of your backup sensors probably failed and you need to replace it. What I will tell you to do is to turn the key to the "RUN" position (keep the engine off), set the e-brake, put the car in reverse and then put your ear next to each of the sensors (4 total). You should hear a high pitch squeal/chirp from the sensors. If you have 1 sensor that doesn't chirp, that is your bad sensor. It will need to be replaced. The sensors can be had for fairly cheap if you look around.
If you have any more questions, let me know. Do not forget to check the wiring for any damage before just replacing the sensors.
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
KarimPA
Sep 3, 2015 07:32 PM
innzane
Sep 2, 2015 10:08 AM
