Rear sensors
Old Sep 28, 2017 | 07:06 PM
Tots's Avatar
Default Rear sensors
Just got my sons 2006 X-Type back from body company and rear sensors stopped working. I checked fuse 33. Advise please!
TY
Jim
Old Sep 29, 2017 | 06:52 AM
Thermo's Avatar
Veteran: Navy
Tots, are you getting a long tone when you put the car in reverse or do you get nothing? Long tone would be atleast 1 sensor not working, but the brain box has power. If this is the case, block the wheels, put the car in reverse (may want the help of a second person) and then put your ear next to each of the four sensors. You should hear a high pitch chirp/squeal. The sensor that is not making this noise may be unplugged or bad. May need to buy a new sensor if this is the case.
If you have no noise when putting the car in reverse, the brain box or speaker may be unplugged, otherwise, if the fuse is good, you have a bad brain box and that will need to be replaced.
Old Sep 29, 2017 | 07:14 AM
rapala's Avatar
Check to make sure the reversing lamps are coming on when reverse is selected as the module is powered up when the gear stick is moved to the reverse position.
You could have a dodgy switch on the gearbox. (manual transmission) I don't know whereabouts the switch is on auto transmission though.
Old Sep 29, 2017 | 06:38 PM
Thermo's Avatar
Veteran: Navy
rapala, the reverse "switch" on an automatic is done via the computer, through the GEM module and a relay.
Old Oct 3, 2017 | 12:57 PM
wulfrun's Avatar
wulfrun speaking...
I have the same trouble, no power to the module in the boot. This is due to the switch activated by selecting reverse. I have a replacement switch but having removed the battery I am unable to locate the offending switch. There is one similar, not under the battery but tucked further back under the front suspension strut fixing. It it is the one I am looking for it is a smaller device and located on the rear end of the cluch bell house.
Has any one had success changing this switch and can confirm it's location
Cheers Doug alias wulfrun
Old Oct 3, 2017 | 03:39 PM
Thermo's Avatar
Veteran: Navy
wulfrun, if you have a manual tranny, then you are in the correct location. You should see it sticking out the top of the tranny. Use a deep well socket and unscrew it. Screw it in by hand until it gets a bit snug, then use a wrench to give it a little bit more of a turn till you start to feel resistance. Reconnect the plug and you are golden.
Old Oct 4, 2017 | 03:42 PM
wulfrun's Avatar
Default Thank you Thermo
Hi Thermo
Thanks for you reply. Very useful
Just got back from the tool shop with a long reach box 22mm
My project for tomorrow
Thanks for your help
Wulfrun, France
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
equicor
Oct 3, 2016 09:30 PM
JimC64
Sep 10, 2009 12:44 PM
racerx82
Jul 18, 2007 09:50 PM
