Rear Suspension Problems..Rubbing BAD
Old Jan 21, 2007 | 08:41 PM
IronCobra's Avatar
Default Rear Suspension Problems..Rubbing BAD
Ok, here's the deal. When I had the factory springs on my car and would have vertually ANYONE in back back (not overweight) it would rub when I cornered or when up an incline while turning and it would sit real low with people in the back.
After getting lowering springs it rubs the same (no more no less).
Any idea?
It's a 2003 with 25000 miles on aftermarket 18x8" wheels.
I'mwas thinkingit could be because of the wheels being flush with the side of the car. But after seeing how far the car sits down with rear passangers in it, I have kind of think it is a defective suspension part of some sort.
Anyone else have this problem? I'm wondering if I should get my Jag dealer to check it out or if it is normal.
Old Jan 21, 2007 | 08:46 PM
Default RE: Rear Suspension Problems..Rubbing BAD
Hey there Iron Cobra,
my 2.5 has sport supension and stock 17" wheels - no problems to report.
Buck or Chris might have ideas
Jim C
Old Jan 21, 2007 | 09:15 PM
racerx82's Avatar
I had my suspension lowered and don't have that problem, just the other day, had all 4 seats occupied (3 big guys and little ol me) no rubbing...they tried though.....:-)
Old Jan 21, 2007 | 09:18 PM
ORIGINAL: racerx82
ROFLMFAO
Racer in the car with " 3 big guys"
C'mon racer - anythin u wanna share buddy?
Jim C
Old Jan 21, 2007 | 10:01 PM
andersen06's Avatar
ORIGINAL: JimC64
ORIGINAL: racerx82
ROFLMFAO
Jim C
[sm=funnypostabove.gif] I think Jim is poking a bear...[sm=icon_stickpoke.gif]
Old Jan 21, 2007 | 10:15 PM
racerx82's Avatar
Old Jan 21, 2007 | 10:18 PM
C'mon racer,
just messin with ya....lol
Jim C
Old Jan 21, 2007 | 10:25 PM
aquill1's Avatar
Your custom rims are 18x8 right, what size are your tires? I was pretty sure the stock rims whether 16 or 17 inches are both 7 inches wide. Considering yours are 8 inch wide it could possibly be in that... don't know just my guess....
Old Jan 22, 2007 | 12:04 AM
racerx82's Avatar
yeah, kinda sounds like he has the wrong tires/rim on that fine sexy machine
Old Jan 22, 2007 | 01:41 AM
IronCobra's Avatar
It might be the tires and rims. I'm using 225/40/18 all around.
When you have people sitting in the back does the tire tuck under the wheel well?
Old Jan 22, 2007 | 10:00 AM
RudyF6's Avatar
What is your rim offset? I just got 18x7.5 / 40mm offset, and waiting for tires to arrive (same size as yours). Should I be nervous?
Old Jan 22, 2007 | 01:19 PM
aquill1's Avatar
I am looking into well many of things right now but I'm sold on some 19" foose speedster for my jag. The size is 7.5 though not 8. Something you could do is park your car say on a curb or unlevel ground and go to the lower side as the suspension is depressed and more weight is on the low side so the rims kind of tuck. Check her out and see what you find. I found the other day that my tires touch the black fender wall on my jag with the same size rims and tires as stock. The overall diameter should be the same all the way around the car thats why the profile of the tire gets smaller. So your overall diameter can't exceed 26" which you havn't I'm sure but with the different width that changes everything. I'd put money on it that its the width thats hastling you these cars have no rims under the wheel well like all of the other american cars. But thats also why these cars handle and maneuver better than american cars.
Old Jan 22, 2007 | 08:58 PM
racerx82's Avatar
That would suck....doing 120, hit a bump, tire gets shreded by the fender, you lose control, jag rolls like 5 times + bounching off the concrete like it was a basketball....you inside saying to yourself, **** this is gonna hurt....then....damn, should have listened to them guys in the Jag forum....than as the car rolls one more time you say to yourself.....damn, this is gonna be expensive all because i wanted 20 inch rims......as the jag comes to a screeching stop on it's roof...you look around and see the 6 airbags deployed...you say to yourself...****, i don't remember them going off......crawling out of your car, pants full of crap...you say to yourself....mom was right, always bring a clean pair with you......
Old Jan 22, 2007 | 10:34 PM
aquill1's Avatar
Whether the rims are 16 or 19" shouldn't matter as long as they are compensated in the profile of the tire. Say I want 19"s the stock tire is 45 and if I have 17"s the size is 45. 18"s 40, 19"s 35. As long as the overall diameter of the overall rim and tire is the same they won't rub any more or less with the stock suspension. I hear bojangles though my fronts rub on the inner wheel well on the black plastic, and I have some slits on the edge of the tread on mine and they are the same size as the stock rims and tires. 225 45zr17? I wish I had the aguilla's or the newer 18's...
Old Jan 23, 2007 | 12:17 AM
racerx82's Avatar
so let me see if i have your version of size down....lets say i have a 7 inch pecker, but upgrade to a 9 inch, the 9 inch will work just like the 7, just looks better with no ill effects and no rubbing of the inner walls?
Now where are them boots....i need to go for a walk....
Old Jan 23, 2007 | 03:21 AM
IronCobra's Avatar
Here is my setup.. I'm sure it is rubbing on the inside fender wall. I'll check tomorrow morning.
Old Jan 23, 2007 | 01:39 PM
RudyF6's Avatar
Iron Cobra - your rims are sweet! What brand/model are they?
Old Jan 23, 2007 | 01:49 PM
Yeah Cobra, love the rims mate, look good.
Did you paint your calipers?
Jim C
Old Jan 23, 2007 | 10:37 PM
racerx82's Avatar
nice, but i'm sure you got some rub marks....get your fenders rolled and you should be good to go....
rim offset on a jag is 46 or 48 i think
